Question about Toshiba Computers & Internet
Rtl81885 wlan adapter - Toshiba Computers & Internet
Atheros AR5007EG can't connect via WPA2 to WLAN on Windows XP
WPA2 is considered insecure and hacked years ago.
You might try WPA, or get a different Adapter.
Mar 03, 2018 | Fujitsu Siemens Computers & Internet
How do i download network adapter for my dell tower, its service tag is C0WST21
please page the URL below in your browser and click download button.
http://download.cnet.com/Network-Dell-Wireless-US-WLAN-Network-Adapter-Card-Wireless-1370-802-11-b-g-WLAN-MiniPCI-Card-Wireless-1350-802-11b-g-WLAN-miniPCI-Card-Wireless-1450-802-11a-b-g-Dual-Band-WLAN-miniPCI-Card-Wireless-1350-WLAN-802-11b-g-PC-Card-TrueMobile-14/3000-2112_4-109107.html
Feb 19, 2011 | Dell 04U852 Network Adapter
No wireless network adapter found after format acer aspire 3610 and the same problem in the bluetooth
you can download the WLAN adapter here
and the bluetooth adapter here
Your machine may have internet conectivity issues without the WLAN Drivers. So you may need to download these drivers to a USB flash drive. Then transfer them to your acer.
Dec 03, 2010 | Acer (D10709-002) (D10709002) 802.11g/b...
WLAN driver cant be instaled wlan adapter cant be found
try to conect in another computer the wlan adapter for testing if its works
Aug 06, 2010 | Fujitsu Siemens LIFEBOOK E8010D PC...
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
The linkssys usb adapter does not connect automatically to the WLAn router. it always says "win xp manage the wlan" but this is not true
the problem may be caused by the installation of the usb adapter's WLAN software (WinXP already has a built-in WLAN). Ty uninstalling the adapter's WLAN monitor, unplug and replug the USB adapter to your computer and it will be installed automatically. Once installed, Go to Control Panel >> Network Connections >>Right click Wireless Network Connections and click View available wireless networks. Try manually connecting initially to the router and see if it will be automatic from then on.
Jul 05, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
Dec 20, 2008 | Computers & Internet
TwinMOS wlan adapter
The best thing to do since it hangs is to unistall the driver, reboot and let it re-install itself. This is the easiest thing to do and usually works.
If you are a novice and need directions to do this, post a reply. I've just started as a "expert" on this website and am not sure of the user levels of the person asking the questions.
Nov 25, 2007 | TwinMOS Technologies 128MB Twinmos 802.11b...
Computers & Internet Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
