Question about Ovens
Battery for ignition on cooker hotpoint ultima
Where does the battery go
2 Suggested Answers
rohntech
  • 422 Answers
SOURCE: How do I set the timer on my Hotpoint Ultima
try to re-read the operating manual of your unit if you forgot it, it's all there
Posted on Feb 04, 2011
Where do i find batteries for ignition in my creda expression l152g gas cooker ?
Not normally batteries, most are mains powered, but your is a single AA battery. The manual states;
The battery is not covered by the guarantee. Use an alkaline AA battery. The battery holder is located in the plinth panel below the oven door. Open the oven door fully. Press the tag on the left hand side of the battery holder/cover and withdraw it just enough to get access to the battery. Fit the new battery with the end marked "+" on the same side of the battery holder as the red lead. Replace the battery holder by pushing it firmly into the hole in the plinth.
The spark unit is usually under the hob on the left side. Check the connections as they can get really messy and even break through. Also spray the igniter posts with oven cleaner and leave for an hour, clean off with a plastic brush and water. Dry thoroughly. On the hobs, remove the burner and wash them, the underside as well as they rely on the earthing through the aluminium ring, remove and clean that too.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HBC150GG.pdf
Feb 17, 2018 | Creda Ovens
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Dec 11, 2014 | Hotpoint SY36 Style Line Stainless Steel...
My newworld newhome cooker's ignition does not work. Please could you tell me where the battery goes as I cannot find it.
The battery is in a case (plastic holder) left hand side right near the floor in the plinth, opening the oven door will make it easier to see. (Assuming I have the correct model)
Dec 09, 2013 | New World Ovens
Chef premier 091S16FE1 gas cooker. Igniter will not work in grill or oven. Switch tests ok. Need wiring diagram. Would like to know if there is a fuse in the system.
I dont have a diagram but most Chefs have a wiring diagram stuck behind the lower kickpanel or underneath the warming drawer ( if fitted) The Premier was a fairly basic unti when it came out. A lot of these had battery ignition. Look behind the kickpanel or under the warming drawer for a battery box. ( About the size of a matchbox) and has a 9volt radio battery.
I have not seen fuses in these ovens for over 10 years , so I would suggest that yours doesnt have one.
Jul 26, 2011 | Ovens
How do I set the timer on my Hotpoint Ultima cooker to end at a specific time after 2 hours cooking?
Feb 04, 2011 | Hotpoint Ovens
Pilot not sparking , where is the pilot light
That all depends on the make and model of cooker.
On many models it's a single 1.5v AA battery and is somewhere under the lower front edge of the unit. If it's a cooker/range you can access it by pulling the cooker forward, tipping it back and supporting it. Built in ovens (and hobs) usually have mains-power and supply the igniter circuit via a transformer, but on the few built in ovens without mains power the battery is usually at the bottom of the unit close to the front. Depending on the design either the entire oven has to be partially withdrawn from the housing or there is often a removable air inlet panel or grille with the battery holder just behind.
Note that because of the location, the battery holder can be hard to find due to being encased in the inevitable gunge and muck which builds up in these areas, so you may want to allow extra time to clean most of this off.
Oct 13, 2009 | Ovens
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
My igniter doesn't work
The battery holder is located under the cooker, on the right handside. It swivels forwards and holds two AA batteries.
Dec 13, 2008 | Stoves Premier 900GRa Gas Double Oven
Hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
