Question about Compaq Computers & Internet
"Dead" exept for RED light by ON sw slowly flashing
  • John Waters
    John Waters Dec 27, 2013
    Hi Alan Levett, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Need Model number and Operating system to make a better diagnosis.
  • Alan Levett
    Alan Levett Dec 28, 2013
    Thanks for all the responses. Being new to the town, I contacted a dealer from whom I recently purchased a 'pre-used' laptop, and he very kindly ran a quick test for me, pronouncing the PSU as DEAD.
    Back home, I removed the lid and found that it is was a 'suicide' case by an electrolytic. Thus the PSU is deemed NWR.
    Again, many thanks
    Alan
What does 3 flashes of the red light mean on an amana model ptc153a35ac ?
Here are your Amana flash codes:
Steady On - Normal
Off Controller Failure
1 System Lockout
2 Pressure Sw stuck closed
3 Pressure SW Stuck Open
4 Open - High Limit
5 Flame sense without gas valve
6 Open rollout or open Fuse
7 low flame signal
8 Check igniter or improper ground
continuous flashing - reversed AC polarity
Sep 11, 2014 | Heating & Cooling
1991 honda accord turns over wont start . when key in second postion no lights on dash exept for battery light
blown fuse.
the CEL lamp must glow, or the ECU is dead. (no power)
the CEL is very important lamp telling you the ECU has power
and it thinks(sic) that it is ok, (basics)
if the lamp is burned out, it become hard to work the ECU.
as this ECU flashes codes for errors,
check all fuse. in both boxes.
Feb 05, 2014 | 1991 Honda Accord
I have been putting new expensive batteries in but is still spends a minute flashing orrange then flashes a red light and says "error" as if my batteries are dead??
Sep 11, 2011 | Sony HVL-F32X TTL Flash
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
On Power on Green light flashes slowly a few times as it always has, then it starts flashing about every second. After a turn red
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout.....
Aug 10, 2010 | Panasonic PT-60LCX64 Television
Our machine has stopped working....the alarm light is on and flashing slowly so we have gone thru all the steps in the book to find out what is wrong. When we turn the machine on, the green lite goes on...
If red light slowly flashing....Please check brewunit,dregdraw, door and coffeebean lid is properly in .
If flashing fast..means ventilate(prime the machine)
If itis steady..no water in the tank or time to empty the drip tray.or the more serious case the grinder is not working or not self testing.
Nov 17, 2009 | Saeco Odea Giro Plus Coffee Maker
RED LIGHT FLASHING NOTHING ELSE WORKS
Red light flash slowly but bright and nothing more, can't turn it on, won't light up. What must I do?
Jul 25, 2009 | RIM Blackberry 8110 Cellular Phone
ESA 42" plasma will not turn on
Find a power supply that was the problem with my. Exept my tv now dont have picture Cause ysus board is dead..
Nov 10, 2007 | Televison & Video
Computers & Internet Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
