Question about Thomson Audio Players & Recorders
Connect wireless headphones to tv - Thomson Audio Players & Recorders
3 Suggested Answers
SOURCE: innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: HOW DO I CONNECT WIRELESS HEADPHONES TO MY HOME
Did you get a small USB receiver that you can insert into the USB port of your television system? This usualyy works here, but 'here' is Belgium.
Posted on Aug 28, 2012
There is no bluetooth listed under my devices on my new Vizio D43-D1 tv. Can I connect it to Bluetooth speaker?
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
Feb 28, 2017 | Vizio Audio Players & Recorders
How to connect wireless headphones to TV
The TV has to have bluetooth connection or a place to insert a bluetooth dongle, so the headphones can be paired with the tv
Feb 16, 2015 | Ematic Wireless Headphones and Transmitter
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
Wireless headphones won't connect with tv
ENSURE THAT THE SETTING ON YOUR TV SET HAS BEEN SET. DOUBLE CHECK IF THE HEADPHONE IS COMPATIBLE WITH YOUR TV SET
Sep 12, 2012 | NexxTech High Quality 2.4ghz Wireless...
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Wireless headphones
you need a stand alone tv tuner with audio/video out
how to install:
1. connect tv antenna to tv tuner
2. connect tv tuner video out to tv
3. connect tv tuner audio out to your wireless headphone control tower.
Fixya... GOOD DAY!!!
Sep 14, 2008 | Computers & Internet
Top Thomson Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
