Question about Thomson Audio Players & Recorders
Connect wireless earphones to the tv - Thomson Audio Players & Recorders
How can iI connect the earphone on my tv
Through the 3.5mm headphone jack from your headphones, its a pretty small hole usually to the front of the tv set, being so small you may have to look for it. If it is wireless you will need to connect the main headphone system to the back of your TV (audio in jack) then ensure system is powered on and headphones are charged.
Nov 07, 2016 | Televison & Video
Where is Earphone area on Prima model cv2011 tv/dvd set
I'm sorry to say but this model of TV doesn't not have any headphone jacks.
May 02, 2008 | Prima CV2011 TV
Insignia Wireless headphones Model NS-WHP314 own for 1 1/2 years.Left earphone no longer transmits sound. Connected to a Samsung TV. When I tap on earphone, it will transmit for only a minute & stop.
Take it to a professional to get it looked at.It could be a lose wire on the battery but even the smallest mistake and you will destroy it completely
Jun 19, 2016 | Insignia Audio Players & Recorders
How do I get the tv sound on after plugging speakers into audio on my TV?
That's what's 'sposed to happen. You get TV sound OR sound through headphones - not both
Nov 28, 2015 | Sennheiser Rs 180 Digital Wireless...
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
I need help installing A Merkury Innovations Wireless HI-FI Headphones to a Tv
hello, i have a philips wireless head set and this how i set mine up, i take it you've got the sensor with long black wire attach to it this plugs into your earphone socket on your tv set then plug the power adaptor the sensor switch on make sure the sensor pointing towards you and put the batterys into the earphones and switch earphones on you should have sound get back to if you have trouble thanks
regards
shaun
Nov 28, 2010 | Audio Players & Recorders
How to connect my wireless headphone to a Panasonic LCD TV, there is only a single earphone jack mine has got 2 plugs
That's a new one, 2 plugs would indicate seperate audio ( right and left ) or 4 . Try this go to RadioShack and buy a Y that you can plug both plugs into and then plug the single plug into the TV jack. Look at the plugs on the headphone sender do the plugs have a single band or double? If single use above solution, if double just plug 1 plug in.Good Luck.
Sep 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Logitech wireless earphone not connecting
the problem may be in logitech earphone......after using some days....it may have got repaired....if it is repaired then the connection problem will come....otherwise if you are using antivirus....check the firewall.....if the firewall is not allowing skype to connect to internet....these problems will arise....i am a software engineer and i have experience in these areas....thats why i am suggesting this idea....try this...it will work.....
Sep 19, 2008 | Logitech Cordless Internet HandsetĀ for...
Connecting MY JW120
redbeer, I have JW120 and could help. How do we get in contact? 88Reliant gmail
Dec 09, 2007 | Audiovox JW-120 Consumer Headphones
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
