Question about NetGear DG834G Router
I would like for you to send me my password
I would like to get my password my router is working fine I need for my son to use His I-Pad
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Posted on Dec 29, 2013
I need to know what my password is
If you lost your password you will need to reset into factory settings. There will be a pin hole near power wire use a tooth pick or paper clip or something of thAt size and push in and hold for 30 seconds. You will have to reset all settings. Or if you never set the password try admin as user name and password as password. That is usually the factory set info
Dec 27, 2013 | NetGear DG834G Router
My router is working fine I want to add my I-PAD and want wifi to work
on your computer, in a web browser type in 192.168.1.1 to access the router's control panel.
You will need to enter admin in the user id and admin in the password, assuming it is in the default state.
go to wireless and ensure it is active, then go to wireless security and note the password key, or type in your own. then save the changes. You should be able to go to your iPad and in settings / wifi select the router then key in the wireless password key you entered above. NOTE: if this does not work, on the iPad, select the i beside the network name and the "forget this network" - then go back and try connecting again.
I had my router working fine then messed it up by my son screwing with the security password I have left it unplug and would like to get it going again.. How is this possible when it seems that nothing is...
Hi Megan,
On the back of the router there is a hole, probably marked 'reset'. Press and hold this button for 30 seconds and this should reset the router to factory settings. After doing this, unplug the power from the router and your modem. Plug in the modem first - wait one minute. Now plug in the router and hook everything up. Now you can set a new password on the router to prevent unauthorized access.
Please let me know if this doesn't work and I can help further.
Regards,
Joe
Jan 02, 2011 | Belkin F5D8236-4 Router
Just installed a TP-Link TL-WR940N router. IBM and Dell laptops connect fine. My son's Toshiba Satillite will not?
check to see if you inserted router name and WEP password correctly in your son's computer. I'm thinking you were tired when you got to your son's puter.
regards,
Digital Denizen
rate us and ask another question if it doesn't work
Nov 27, 2010 | Toshiba Satellite A215-S4747 Notebook
My son has an xbox 360 with an xbox Live account it works fine except when he tries to go online from his friends houses apparently it comes up There's a problem with the credentials your using to sign in...
Hi. This must be the router password that xbox is trying to connect. Your home routers password is basically saved to your xbox logon credentials. If the xbox will connect to another wireless router and sees that the password he knows is not the password that was save inside the console then you will be getting that error message. Solution is type the password of your sons friends router then this will solve the issue.
Sep 07, 2010 | Microsoft Xbox 360 Console
D-Link DIR-615 wireless modem, unknown password
You need to connect the modem to your computer via the cat-5 cable.
To reset the router, locate the reset button (hole) on the rear of the unit. With the router power on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait for 30 seconds to access the router. The default address is 192.168.0.1 when logging in, the username is "admin" and leave the password box empty.
If you need the manual, you can download it at:
http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
Please rate this solution. Thanks.
Feb 22, 2010 | Computers & Internet
Windows 7 and D-Link DSL-2640R router. I have recently bought a new laptop which supports windows 7, the talktalk cd will not work so i do not know my routers settings. Well my internet connection always...
Hi
I presume that your internet was working fine before you bought your new laptop. Unless you've done something to change it it should still be working as before.
You shouldn't need a CD - if you think about it you don't need a CD when you log in in Starbucks so why should you need one at home?
The only thing you need to know is the router's wireless name; Talktalk 12345etc, and its password - which is the password your son is using.
I can't explain why you can't connect when your son is connected - as the router should be able to host 253 laptops (very very slowly mind) - unless the router has been set with an access list that only allows his laptop to connect.
Nov 24, 2009 | Computers & Internet
WRT54G router working fine but need to turn on security.
with the wrt54g you need to open a internet browser and navigate to 192.168.1.1
a security screen will pop up to which the username is "admin" and the password is either "admin or blank, (unless you specified otherwise when running the install.
once in click wireless then security in the sub menu (under the wireless link you just clicked) then fill in the boxes
Mar 01, 2009 | Linksys Wireless-G WRT54G Router
I forgot my router psword , i now know how to reset it but i need to hook up my sons ipod therefore i need to do the psword thing but will it knock my sons xbox live system off the live part? i h
If you have forgotten your password, push the reset button on the back of the router. This will reset it to factory defaults.
The factory default user name is "admin" and the password is "password".
You can change the password by logging in, and from the main menu, under the "maintenance" heading, select "set password". You will need to enter the old password once, and the new password twice.
Dec 30, 2008 | NetGear WGT624 Wireless Router
NetGear DG834G Router Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
