Question about Smeg STX2 Dishwashers
Door locked shut
I cannot open my smeg dishwaher door: its firmly locked shut. I have taken the lid off but cannot access the locking mechanism. I cannot find the fixing screw locations for the bottom kick plate either! help!
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Posted on Dec 28, 2013
  • allen christer
    allen christer Dec 28, 2013
    so now we have the dishwasher open, but it's not filling up with water! got the program lights on and it beeps when switched on, but no other sounds!
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Sep 16, 2010 | Whirlpool Washing Machines
MODLE NUMBER WTW6400SW HAS CODE DU AND DI COMING UP WHAT IS IT
Door Unlock Error
If it is a cabrio:
Aug 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer displaying du code with 3 quick beeps
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
My 20 year old dishwaher just broke its lock. Somehow it seized when I locked the door. My husband took it out but we still cannot open its door and take out the dishes. The handle fell out when he tried...
YOU HAVE ELIMINATED THE EASY WAYS, ARE YOU PLANNING ON REPLACING IT OR REPAIR, IF REPAIR CALL A TECH. IF REPLACE, THE LOCK MECHANISM IS AT THE TOP CENTER OF BODY. ACCESS WOULD REQUIRE REMOVAL OF D/W, AND ASSOCIATED CLEAN UP OF THE WATER LEFT. JUST REMEMBER THAT YOU HAVE BREAKABLE DISHES INSIDE. WHEN YOU PROCEED. YOU MAY UNPLUG AND REMOVE THE SIDE SCREWS AND SEE WHAT IS EXPOSED WHEN YOU REMOVE THE BLANK FRONT METAL PIECE.
Mar 10, 2010 | Dishwashers
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code du
Door Unlock Error
If it is a cabrio:
Jul 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Smeg STX2 Dishwashers Logo
332 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
