Question about NetGear Computers & Internet
Router default passwords
My wifi is working fine can you send me my password I need to add a I-pad
  • 3 Answers
Password
Posted on Apr 28, 2014
heuweiler
  • 56 Answers
SOURCE: I need to reset the password for my router D-Link (DIR-300) Router. The default password was blank. But now it does not accept that.
There is a little hole beside the Power Plug.
This is the reset button.
You´ll need a little paper clip to press the button more then 3 seconds.
Then all in the box is resetet.
Posted on May 02, 2009
jeevan.m
  • 392 Answers
SOURCE: default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Posted on Jun 22, 2009
kamal1984
  • 1383 Answers
SOURCE: router configuration password
you can access your router with folowing link
http://192.168.1.1
or
http://192.168.0.1
type suername as "admin" and password is "admin" or blank or "password"
thern you can enter in router configuration then go to wi fi if you set encryption security there then check it is your wi fi security poasword.
Posted on Jun 26, 2009
nyilasrobert
  • 627 Answers
SOURCE: I have Compex WRL254G wireless ADSL router. I need Default passwo
username: admin
password: password
here is the manual too
Posted on Aug 05, 2009
  • 96 Answers
SOURCE: D-Link 615 Default password not working.
Your default admin password should also be blank.
-Comp Doctor
Posted on Feb 01, 2010
Want to add iPad to network but dont remember my password
What you want is to add an iPad to your network. If you mean logging in on your Wifi at home, that is easy, but you probably mean you have lost the password of the router.
Reset the router to factory default: pull the plug and leave it unplugged for at least 10 minutes.
Check on the backside if it has a sticker with the default passphrase. After starting it up try this passphrase on the iPad.
If it has no sticker: Try Google: type in your brand and model of router with added "default wpa password". This might give a default password for your router on some site.
Do learn to adjust the password on your router: mostly you can type the IP address of the router in your browsers address bar
Try 192.168.0.1 or 192.168.1.0 (might be mentioned on the sticker also) then you get a weblogin page for the router.
Mostly you will need as user 'admin' and a password on the sticker.
Search for WPA2 passphrase in the setup and set that notch and adjust to your own password.
Use this password on the iPad:
goto settings - wifi and choose your network, give in your own password.
Good luck!!
Aug 26, 2014 | Computers & Internet
Forgot my wifi password
Many routers have a sticker on their belly with the default password.
Newer routers often have a reset switch to restore default settings.
(needs to be held down for 10-15 seconds). Most router makers host support websites; look up by model#. Good luck!
Mar 13, 2014 | Computers & Internet
My router is working fine I want to add my I-PAD and want wifi to work
on your computer, in a web browser type in 192.168.1.1 to access the router's control panel.
You will need to enter admin in the user id and admin in the password, assuming it is in the default state.
go to wireless and ensure it is active, then go to wireless security and note the password key, or type in your own. then save the changes. You should be able to go to your iPad and in settings / wifi select the router then key in the wireless password key you entered above. NOTE: if this does not work, on the iPad, select the i beside the network name and the "forget this network" - then go back and try connecting again.
Dec 27, 2013 | NetGear DG834G Router
I agreed to download an upgrade on I tunes to my I pad and now it wants my password for my network
First be sure you are connecting to your network. If you don'k know your wifi password, you need to find your paperwork for the router or look up the default password. Find and press the reset button and hold for 30 seconds. This will reset the router to default settings including default password.
Oct 06, 2013 | Apple Ipad I-pad
Model name wbmr-hp-g300h, i have lost the password so it cannot be log in
Did you loose WiFi access password or router password?
If it's WiFi password then you can connect over Ethernet cable, login to the router (default password is blank) and change WiFi password.
If it's router password you will need to reset it to factory defaults and setup everything from scratch.
Here is the manual with the details.
Wireless Configuration, p. 40
Factory Reset, p. 67
http://cdn.cloudfiles.mosso.com/c85091/WZR-G300N-Manual-v1.1-web.pdf
Aug 20, 2013 | Buffalo Technology AirStation Nfiniti...
I want to use my Ipad with my d-link wifi system, but I do not know the password to unlock the system. How can I retrieve this password.
If you have not changed the default login to the router then the login is admin and the password field is blank.
However, if you have changed the default login and do not remember it you will need to press the reset button on the back to restore the router to it's factory default settings then you can use the login above.
Hope this helps!
May 03, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
I cannot password protect my old router. I have a new laptop and the internal wifi and router work fine but I cannot set a password on the router. When I try to get to the settings I hit a user/password...
try hitting the reset button on the router and setting everything back to default. this sets the passwords to nothing.( on a d-link) anyway. then you can set up the passwords that you want
Feb 27, 2011 | Computers & Internet
Master password for wifi
I need master password of wifi
Oct 25, 2010 | Computers & Internet
-Comp Doctor
Feb 01, 2010 | D-Link DIR-615 Wireless Router
I have a t-mobile linksys router. old computers and phone work fine. new laptop doesn't because i forgot or don't know the password for the router. is there a way to find this?
Connect your router to computer with ethernet cable.
Then you can access it with following defaults link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password".
Then you can see configuration of router.
Click on wireless and then wep security there is wep code it is your password to connect wifi.If it in * or # format then you need to set new add new WEP code then save settings it is your new password for connect internet.
Let me know if you need further assistance.Thanks for uisng FixYa.
Dec 07, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
