Question about HP LaserJet 3055 All-In-One Printer
5 initialization press - HP LaserJet 3055 All-In-One Printer
    New Friend:
Earo mark one
Posted on Jan 22, 2014
  • logidass
    logidass Jan 22, 2014
    hp 3050
    earo mark one
There is now no ring associated with incoming calls on line 3, but otherwise that line functions for both incoming and outgoing calls
http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
page 80,do this first,
25611223-5sp5orn0xnhdqraxk0v0421v-4-0.png then if you want to reset both phone and base,
clear base unit settings to default,
1 Press {MENU}. 2 Scroll to "Initial setting" by pressing {<} or {>}, then press {ENTER}. 3 Scroll to "Initialize base" by pressing {<} or {>}, then press {ENTER}. 4 Scroll to "Clear settings" by pressing {<} or {>}, then press {ENTER}. L The "Clear settings?" screen is displayed. 5 Press {CLEAR}. L Confirmation tone is heard.
clear handset to default,
Press {MENU}. 2 Scroll to "Initial setting" by pressing {V} or {^}, then press . 3 Scroll to "Initialize HS" by pressing {V} or {^}, then press . 4 Scroll to "Clear settings" by pressing {V} or {^}, then press . L The "Clear settings?" screen is displayed. 5 Press . L Confirmation tone is heard.
Mar 27, 2015 | Panasonic KX-TG4500 Phone
How do I change language settings on my Dell V313 printer
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Printhead error
Apr 22, 2013 | Dell V313w AllInOne InkJet Printer
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
Boss br900cd factory defaults re install
Here is the newest updates for it, http://www.bossus.com/gear/productdetails.php?ProductId=718
1. Press [UTILITY].
2. Press CURSOR [ ] [ ] to move the cursor to "INI,"
and press [ENTER].
3. Press PARAMETER CURSOR [ ] [ ] to move the
cursor to "ALL," and press [ENTER].
The confirmation message "Are you sure?" appears in
the display.
4. To continue the initialization, press [ENTER] (YES).
To cancel, press [EXIT] (NO) (or [UTILITY]).
When [ENTER] is pressed, initialization begins.
After the initialization has been completed, you are
returned to the Play screen.
You can perform the same initialization with "INIT
ALL," by holding down INPUT SELECT [GUITAR/
BASS/MIC2], [MIC], and [LINE] while turning the
POWER switch ON, then pressing [ENTER].
Mar 03, 2013 | Roland Boss BR900CD Digital Recording...
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
Reset scanner
Please try this:
Hope that helps.
Happy Scanning!!
Oct 24, 2012 | Radio Shack Pro-97 Handheld Scanner
I have a printer it is modle is Hp LaserJet p4015n, when i start it give me this error: (49.00FF ERROR To continue turn off then on). when I turn off then on it give me agane this error. thanks for help,...
HP 4015 NVRAM & hardrive initialization
Solution
A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on.
2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit.
3. Press the back arrow . The message INITIALIZE DISK displays on the control panel.
4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
 NVRAM initialization
Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display.
2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit
3. Press the up arrow .
4. Press Menu . The message SKIP DISK LOAD displays on the control panel.
5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Good luck
Dec 12, 2009 | HP LaserJet P4015N Printer
How to set a deh-p4000ub car radios clock
try this:
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
HP LaserJet 3055 All-In-One Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
