My computer will not boot up properly I get this error file not found HDBRLOADER.exe and I cannot reset to factory settings, can you help please
Laptop is Fujitsu lifebook a series, I think it is a hard drive problem but do not know how to repair, do I go into bios set up .
    Sergeant:
  • 246 Answers
Can tell me spesific problem ?
Posted on Dec 27, 2013
kleeper
  • 87 Answers
SOURCE: BIOS Password reset on Toshiba A135-S2276
Use a boot disk such as, the Ultimate Boot CD or the Ultimate Boot CD for Windows if you don't need a BIOS password. If you do, try Toshiba.
Posted on Oct 20, 2008
mdsaeed67
  • 849 Answers
SOURCE: fujitsu n series n3530 lifebook
you need to open your laptop, you will find it on the motherboard, near the battery you will find the CMOS reset jumper or switch.
Posted on Oct 22, 2008
SOURCE: How to remove hard drive from Fujitsu Lifebook N3010 PC laptop
Remove the DVD drive, and then there are 4 outer screws holding the hard drive chassis in place. There are also 4 inner screws that hold the hard drive to the removable hard drive chassis, those do not have to be removed to remove the hard drive from the computer. Carefully remove the screws so they don't fall into the holes on the sides of the screws, and then slide the hard drive out of the pin slots.
Posted on Nov 15, 2008
  • 82 Answers
SOURCE: How do I remove the bios battery for the Fujitsu
Procedure...
http://forums.techarena.in/portable-devices/1198300.htm
Posted on Jun 29, 2009
Brandonmxb
  • 115 Answers
SOURCE: thermal sensor error on fujitsu
Don't worry. I'm sure it will be fine, as long as it's not over heating or smoking. lol. But seriously, you should be able to disable that error in Bios under one of those options. If you are still having problems contact customer support for help.
Thanks,
Brandonmxb
Posted on Dec 09, 2009
Hello, how do i do a factory reset with command prompt. the ususl method does not work as only optionsrepair and recovery ect are there. no reset option. dell latitudee7240 win 7. rstrui.exe. gets is
The instructions are:
  1. Turn on the computer.
  2. Press and hold the F8 key.
  3. At the Advanced Boot Options screen, choose Safe Mode with Command Prompt.
  4. Press Enter.
  5. Log in as Administrator.
  6. When Command Prompt appears, type this command: rstrui.exe.
  7. Press Enter.
  8. Follow the wizard instructions to continue with System Restore.
Restore To Factory Settings - Guide for Windows XP, Vista, 7, 8, 10..
before you try this go to this link and have a read up first.
factory reset with command prompt Google Search
Oct 29, 2017 | Command Computers & Internet
Tip
NTOSKRNL.EXE is missing or corrupt.
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
on Dec 27, 2009 | Computers & Internet
It keeps saying that ntoskrn1.exe is missing
It is pretty much crashed....hard. Might want to reload the OS. Yes you can recover from that, but it is not worth the time and frustration to do it...Provided you can afford to lose whatever you had on the primary partition (C:\) drive. Let me know if you need other asst. It is a little complicated to explain. How many machines is this affecting? All of your E-Machines?
Aug 13, 2009 | Computers & Internet
Session 3 initialization failed
Ok, after countless hours searching and sleuthing for this issue, I could not find a resolution...until now. This is my first post ever on a technical forum, so be gentle to me. I will probably never reference this form, so you if this helped you, please let me know by sending me comments to my email at: cancermage@hotmail.com
Technical Symptoms: Blue Screen (BSOD) Session 3 Initialization Failed (Session3_Initialization_Failed) STOP 0x0000006F (0xc0000034) This BSOD would load for both normal and safe mode. The operating system in question was Windows XP Home SP2.
Reason: The issue occurred after I ran a virus scan using a PE boot disk that deleted the C:\windows\system32\smss.exe system file.
Resolution: By using the "dir smss*.* /s" at a DOS prompt from the PE boot disk, I was able to search the whole computer for any available files and it found a clean version in a directory. So to fix the issue I copied C:\windows\$ServicepackUninstall$\smss.exe to C:\windows\system32\ using a PE boot disk.
Acknowledgements: http://support.microsoft.com/kb/153742 , this link gave me a hint that it may be smss.exe (even though it references win2000). Upon looking at the antivirus logs, sure enough the smss.exe was found to be infected and deleted it as it could not disinfect it. I'm assuming if I did not have a virus free smss.exe file on the C: drive in another folder, I may have to pull it from a CD or find it online.
Sincerely,
John White A+,MCP,CCENT,CCNA,MCITP cancermage@hotmail.com
Jul 11, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Restore factory Settings on a Dell Inspiron
hi..
if you have windows xp then you need to turn your computer as soon as you do that before you see the windows xp logo hold down the control key and keep tapping f11 key.it should take you to the screen fro factory settings and if it is windows vista then you can go ahead and press f8 and then choose repair my computer,hit enter which will then prompt you to login in once you log in it will tell you to choose the options from the options listed below choose the one which says restore factory default...you computer will be restored to factory settings..
vedhick
Feb 26, 2009 | Motorola Mobility OEM Bluetooth USB PC...
Hi I have Sony VAIO VGN NS135 laptop on which I have installed Windows Vista Ultimate Now there is error in booting and showing these lines Booting 'Windows Vista' acpi Vista Loader 2.1.2 Done! fallback 1...
This means that the operating systems was not installed properly...."Boot manager is failed... and ntldr is the main file... which help computer to boot up..." try reinstalling the operating system again...
Jan 12, 2009 | Sony VAIO VGN-NS135E/S Notebook PC
Bootup failure
Cause:
  1. Keyboard issue
Solution:Keyboard issue
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
OS Loader v4.01
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Dec 05, 2008 | Acer Aspire 3624WXCi Notebook
Error: windows root>\system32\ntoskrnl.exe
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
ACER DESKTOP COMPUTER
Related errors:
Cause:
  1. Keyboard issue
best regards wish u give me a good rate ^^
Aug 15, 2008 | Acer Computers & Internet
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
