Question about Amcor Dehumidifiers
Amcor amd 720 keeps clicking
My amcor amd 720 keeps clicking
Instructions for AMD 720 dehumidifier
www.amcoruk.com/air-treatment/products
Jul 23, 2016 | Dehumidifiers
Amcor Dehumidifer TC120 - Circuit Board Required
It is not your relay. Mine did the same and the problem is the resistor that drive it goes short so the relay clatters as the circuit is trying to control it. The actual fault is the 78p153sp driver. You can change the transistor, a pnp will do the trick but the driver is dead. I'm currently looking for this IC and they're hard to find, cheap Chinese tat. So instead I'll likely fit a temp sensor that detects when the cooling coils reach about 4deg and switch the fridge off because shorting the relay will just cause the cooling to stay on and you'll get ice, it needs to cool, collect moisture, switch off, warm up and dump the moisture...crude but it works. This unit is worth saving.
Jan 06, 2013 | Amcor Dehumidifiers
Fan not operating, believe the mother board needs replacement, where could I purchase one for Amcor Dehumidifier Model # AHD-65E
Unfortunately, you will be hard pressed to find parts for your Amcor Dehumidifier. This British Manufacturing Company of electrical household goods went out of business 03/11/2009. Although, there are some of their appliances are still on the market, you can rest assured their warranty is useless.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Sep 19, 2011 | Amcor Dehumidifiers
My amcor dehumidifier tc120 has started clicking recently and now its out put is poor the unit is used in a cellar just to keep control of humidity it works 24/7 then has few days off when full untill i...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 17, 2011 | Amcor DC930 Dehumidifier
I have a Amcor DC830H and have lost the operating instructions . Could you please inform me as to what lights should be showing when using the dehumidifier part. Thank you
Nov 16, 2010 | Amcor DC930 Dehumidifier
LOOKING FOR amcor dc800 manual. Any advice? thanks
problem solved. found instructions.
thanks
Oct 24, 2009 | Amcor Dehumidifiers
Where, in the UK, can I obtain Amcor replacement parts?
the thermal break is there for a reason, the motor has overheated, if this was due to a towel or other item covering the unit great remove the the obstruction and replace the thermal break. however the major cause is that the bearings have dried up on the motor and it has started to seize, which means replacement.
Mar 31, 2009 | Amcor MD250 Dehumidifier
Dehumidifiers Logo
169 people viewed this question
Top Amcor Dehumidifiers Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you an Amcor Dehumidifier Expert? Answer questions, earn points and help others
