Question about Acer Extensa Computers & Internet
Water type liquid is coming from charger and a continues sound coming from charger like some thing is sparking in it
  • 39 Answers
Bin it get a new one. Sounds like its burning out.
Posted on May 27, 2014
2 Suggested Answers
  • 33 Answers
SOURCE: fix charger port
Don't fix it replace it with a new charger
Posted on Dec 27, 2013
How do you fix liquid locked in a homelite mp88 chop saw
EXTREME Caution should be used. A FIRE can result if this is done improperly !
1) Remove spark plug, ground the plug wire if possible
2) Make sure ignition is in the OFF position
3) NO choke
4) Wide open throttle
5) Shop rag over spark plug hole
6) Pull until no liquid comes out of plug hole
7) Re-install spark plug
8) Continue to pull recoil with throttle open, NO choke
9) Engine will start slowly with huge amounts of smoke, run until the smoking stops.
Feb 15, 2017 | Homelite Garden
Fix charger port
Dec 27, 2013 | Acer Extensa Computers & Internet
Starter engages but wont turn engine over starters been rebuilt still doing same thing
sounds like,yes, Might try pulling the spark plugs and try it then,
if the intake gasket leaked or even fuel leaked into a cyl. when
the compression stroke comes up liquid won't compress so the
engine won't turn over.
Mar 21, 2013 | Cars & Trucks
The light on the charger comes on then goes off because i wasted water on it
sounds like you need to get a new charger. water is a killer of most electrical things. have you tried letting it dry out?
Feb 15, 2012 | Motorola Mobility P323 Battery Charger...
Was boiling water and running microwave and a popping sound and blue spark appeared, it still seams to be functioning normally but am worried about what happened???
if you mean you were boiling water in a microwave, then A) that is a dangerous thing to do as any liquid in a microwave is very volatile and B) were the dishes ,containers etc you had in the microwave free of all metal? as that is what would have made the blue spark , when the microwaves connect with metal
Oct 09, 2011 | Frigidaire PLMV169DC Microwave Oven
Maytag mfi2568aes makes continuous buzzing noise when water dispenser is depressed (sounds like is coming from rear of machine). Water comes out, but at a trickle. Ice is fine
From your description, the only thing I could think that MIGHT cause those types of indications is the dual water value. http://www.partselect.com/PS2069865-Whirlpool-67006322-Dual-Water-Valve.htm?SourceCode=1&ModelNum=MFI2568AES
IF you are sure that the ice maker fills NORMALLY. If it doesn't then I would suspect the filter.
Jun 12, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU PUSH THE BUTTON TO MAKE A POT OF COFFEE, THE WATER DOESNT STOP AT ONE POT IT MAKES 6-7 BEFORE IT STOPS. IF YOU TURN OFF THE MACHINE WHEN THE DECANTER IS...
Sounds like your timer part #32400.0002.This is the new type timer which replaces the dial timer.Another thing is does this happen when you turn on the on/off switch? I would also check your liquid level probe in top of tank.Always a possibility bad liquid level board.If it only does this when you push the brew button the timer is bad.
Feb 07, 2011 | Bunn VLPF Coffee Maker
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Liquid noises coming from the dash board
heated water goes to your heater core under your dash..though you shouldnt be hearing it usually..be sure water level is up at radiator overflow reservoir and pay attention in cabin of any sweet smell of coolant indicating a failing /leaking heater core....look for damp carpet on passenger front area if suspicious
Sep 29, 2008 | 2004 Jaguar X-Type
Melted spark plug wire
You did not say if you were overheated,also what liquid and what is meant by spark plug filled with liquid, if plug was removed from block! (antifreeze?) Check oil and if water in it you more then likely have a blown head gasket. Hot engine is what most likely caused burnt wire. They make sealers that are put in radiators to repair leaks if cost is a problem and you are comfortable using them, and if not, have head gasket replaced which can be quite costly. Mechanic can determine cause with a compression test. Other things you would be wise to consider if installing new head gasket would be changing water pump,timing belt and crankshaft seal as while as the other belts that need changing.Of course this would depend on whether you planned on keeping the vehicle and if it was worth it. You can talk with a mechanic about using a sealer if this is the problem. I know of no other liquid it could be other then antifreeze.Oil is unlikely. P.S You might want to find out where the oil leak is and correct it before you do more damage!
Jul 09, 2008 | 1990 Toyota Cressida
Computers & Internet Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
