Question about Sewing Machines
Empisal sewing machine needle broken
Needle broken. Do I need to buy empisal needles or any sewing machine needle?
  • Anonymous Mar 25, 2014
    I do need new needles and needle sponges for my Empisal 151
  • Sewing Machines Master
  • 7,365 Answers
Try these 2 sites and ask them about the needles
a1sewingmachines.com
or
sewvacdoctor.com
Posted on Dec 27, 2013
4 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: My sewing machine needle is hitting the top of the needle plate
basically have to bend it carefully back by hand.... if you have a straight edge or even a small leveler (the kind with a bubble) you can check which direction it is bent and gently bend it back a little each time.
Posted on Mar 29, 2009
SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Posted on Dec 20, 2009
SOURCE: sewing machine needle is stuck and the machine will not move.
you should go with the flow, just take a deep breath hayete w byemshe el hal
Posted on Nov 28, 2010
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
Broken needle stuck in needle holder stem.
At the very top of the needle, there is a screw that points horizontally to the right. Loosen that screw and the broken needle should fall out.
How To Change Your Sewing Machine Needle
Jan 16, 2016 | Singer Quantum XL-6000 Computerized Sewing...
Need a manual for my sewing machine Empisal Sonata 9312.
Here is a good site to try:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Apr 28, 2015 | Sewing Machines
I have a EMPISAL 403E .. Can I make a roll seam with it. I have an extra plate with a needle in it, but thread keep on breaking an don't know if I need something else to make a roll seam of ju
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Nov 01, 2014 | Sewing Machines
Why does my Empisal sewing machine miss stitches , sew, miss, sew?
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem,, the feeddogs may need to be checked to see why they are not moving the fabric thru the machine.
the
thettttt
the the
Aug 26, 2014 | Sewing Machines
What size needle
Please ask the Janome Sewing Machine mechanic or expert tailor or you buy some near correct size needle take a waste cloth and for your sake of stitch verify.
Dec 30, 2013 | Janome Sewing Machines
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
My manual got lost, need to remove needles, I bought a Empisal Model S4D Overlocker but the manual or CD got lost and I need to get one
look on you tube for overlocker parts instruction.generally the needle is removed by loosenening a little screw which is pushing on the needle from the from.
sewingmanual.com has manuals for sale
Sep 14, 2010 | Yamata FY812 Mechanical Sewing Machine
Needle broken in the needle-slot
Can you please tell me what brand name and model the machine? I need to determine how the needle is normally held in place and how you usually release the needle. I have a couple of ideas but having a little bit better picture of the needle holder will help me provide you the best solution. Thanks
Jan 04, 2008 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
