Oki c510dn service call 142: error - Office Equipment & Supplies
4 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: fatal error msg 142 on Konica 7821 n
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 24 Answers
SOURCE: getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Posted on Jan 24, 2010
maxcarson
  • 7627 Answers
SOURCE: Oki C5600 error: 142
Here's a place to start: http://www.oki.co.uk/support/printer/troubleshooting/detail.aspx?id=tcm:122-98675-16&prodid=tcm:122-2888
Posted on Dec 09, 2012
Oki printer c510dn 547k i nproper carriage lock possion
Looking at the operation panel, to left and slightly underneath it is the scanner lock. There are symbols on it with a padlock. Slide the catch to the unlocked position. You probably caught the catch and unwittingly locked it or partly locked it.
Jan 23, 2016 | OKI Office Equipment & Supplies
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
C530DN 142 error
Image drum up-down movement position detection error. Is the image drum unit removed and installed smoothly? If yes then re-install it If no then Be sure of the connection of the image drum
up-down clutch connector.
- ALSO -
Is the connector of the image drum up-down clutch is connected properly? If yes then Replace the toner sensor board. If no then Connect the image drum updown clutch properly.
Mar 04, 2014 | Oki Electric Industry C530DN Led Printer
Fatal error 142
Color ID up/down error
is detected.
1) Is an Error message displayed?
Confirm that the Y, M, and C ID
units are in position, and reboot
Mar 04, 2013 | Oki Printing Solutions C9650 Led Printer
Message saying drum unit life on OKI PRINTER C510dn
This model OKI printer is not an inkjet printer, it is a color laser printer. and uses color toner cartridges.
The printer image drum unit has reached the end of its service life and this drum unit needs to be replaced.
I suggest you Google the Internet for an OKI image drum unit for your model printer, You will get various suppliers and their prices.
The image drum unit will cost approx. A$200
Feb 07, 2013 | OKI C5100n Laser Printer
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Sep 01, 2011 | OKI C5500n Printer
Falal error 173 on oki c5650 after changing fuser unit
Cause:
Resolution:
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Getting error 142 fatal error
Dec 10, 2009 | OKI C5500n Printer
384 people viewed this question
k24674
jasbo
jasbo
