Question about Car Audio & Video
Spec on box for a ssw-f1-1242 - Car Audio & Video
What is the Specs for Digital starsound 12" ssw-f1-1242?
Starsound 12" 2000w Subwoofer
- 700rms
- stamped slim steel basket
- dual 4ohm 2" ASV voice coil
- 40 oz magnet structure
- rubber gasket ring
- silver push terminal
Not that good of quality speakers. You would be lucky if they lasted a couple months pushing 700 watts rms.
Jul 06, 2014 | Orion HCCA 12D Car Speaker
Hi what amp do i use on my starsound ssw-f1-1242 slim sub
any amplifier u use will make the sub work ( if configured for subwoofer play)
my recommendation is that u use between 400watt rms to 1000watt rms ( the smaller the box used for the sub, the more power you can give it)
please note though that playing at high power levels exceeding manufacturers specs needs someone who knows what they are doing (when it sounds distorted decrees power)
also make sure to match the headunits output voltage to the amplifiers voltage (eg. if the headunit output is 4 volt, then make sure to adjust the sensitivity on the amplifier to be at 4 volt as well)
hope this helps and let me know if you have any other question
Jan 02, 2014 | Car Audio & Video
Just looking for insturctions for installing a FCR carm and MRD/SSW exhaust I just got for my DRZ 400
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
May 13, 2010 | 2007 Suzuki DR-Z 400 SM
How to reset a oil light on a 2005 ford freestyle ssw
try un bolting your ground battery cable for ten seconds then hook it back up.if still on you need to have the computer scanned for trouble codes
Mar 09, 2010 | 2005 Ford Freestyle
How to use network inventory ? what is it requirment ?
Installed Windows server 2000/2003/2008 on server PC
Set IP address as 192.168.0.1
     Subnet address : 255.255.255.0
     Gateway :  Blank (only if you use router)
      Primary DNS  : 192.168.0.1
      Secondary DNS : Blank
Set up the server as Domain Controller plus DNS server.Here is the link on how to
1) http://www.visualwin.com/AD-Controller/
2)http://www.ssw.com.au/SSW/Standards/DeveloperInstallationNetworkSetup/Windows2003_01DomainControllerSetup-InstallingActiveDirectoryandDNS.doc
Client setting
Set IP address as 192.168.0.2
Here is the link on how to join the domain
1) http://www.petri.co.il/joining_a_domain_in_windows_xp_pro.htm
2) http://www.windowsnetworking.com/articles_tutorials/wxpjoind.html
Client Operating system must be windows xp pro,2000 professional,Vista ultimate etc
Dec 24, 2009 | HP Pavilion DV5234US Notebook Laptop
NEEDS BOX SPECS
I do have specs on Boston Acoustics. Really serious thump out of any speaker. Mail me and I will send yout the specs. signed100@gmail.com
Nov 27, 2009 | Kicker CVR12 Car Subwoofer
When i turn my infinity servo subwoofer ssw 10 on and it just blows the fuse
Then it has developed an electrical fault and will need to be repaired by a technician. Sorry to bring you bad news.
Do you mean the house fuse, or the fuse built into the back of it?
If it is the fuse in the back of it, are you definitely replacing it with the same rated fuse?
Apr 26, 2009 | Audio Players & Recorders
Counter Strike Hack error
try hacks like HOOK BADBOY open ur counter stirke then double click the hack
Jan 04, 2009 | 321studios Games X Copy (900242) for PC
Replacement Toroid Transformer
If you are refering to the DC +- 65 Volts the AC side will be different. What you need to find out is the average loaded AC volts on the secondary side of the transformer.
Below is the link to one of the biggest transformer companies in the world. I go to them all the time for transformers and power supplies for high end audio equipment and especialy for custom design and construction. I am sure they can wind you a new transformer once they know the exact specs you need.
http://www.hammondmfg.com/
If you do a Google search, there are a fair number of companies that do custom transformer winding.
Jerry G.
Apr 26, 2008 | Audio Players & Recorders
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
