Question about Autodesk 3ds Max for PC
3d max 2014 application has stopped working
Any body help me to solve this problem i try throw C:\Users\--\AppData\Local\Autodesk\3dsMaxDesign\2014 - 64bit\ENU\en-US\plugcfg no work, please any to help me
4 Suggested Answers
  • 85 Answers
SOURCE: 3ds max autodesk is not opening in windows7 ultimate
some software my not be directly open in windows 7 yet, (like if u c, when u install AutoCad 2006 on Vista Ultimate u can't open it directly, 1st u have to right click on it then Run as Administrator, then it will be open and work) like this prob, i sure that u have to right click on the icon of ur software then run it as Administrator, i think it will open. and your problem will solve..
otherwise your version of 3DS Max is not compatible with Windows 7 and you have to install different version of Windows (Like Xp).
good luck.
shafky
Posted on Jun 17, 2009
Right click the 3dmax then open it with administrator.
Posted on Jan 29, 2010
oqro88
  • 10 Answers
SOURCE: autodesk is not opening
Try reinstalling 3ds max if problem is same
1. your 3ds max is corrupt.
2. your Pc system can not handle 3ds max
Posted on Feb 16, 2010
When I click on Favorites and click on a file it tells me that it is unable to find locale data and to please reinstall
First try to use Fixing program. You'll find them on your hard drive: scanpst.exe Your database should be et: C:\Users\[name_of_profile]\AppData\Local\Microsoft\Outlook\
Also some people have found this to work as well:
looking around my system I found a file " C:\Users\<name>\AppData\Local\Google\Chrome\Application\new_chrome.exe" as well as " C:\Users\<name>\AppData\Local\Google\Chrome\Application\chrome.exe".
When I double-clicked on the new_chrome.exe" it was changed to old_chrome.exe.
When I next clicked the chrome.exe all worked!
Perhaps others will benefit from this without any re-installation or registry modifications.
Mar 10, 2014 | Google Chrome
3ds Max on Windows 7 x64bit
Call to Our Window Technical Support Number 1-800-204-4427 for Windows 7 and Get Instant Resolution of Your Query.
Apr 15, 2017 | Autodesk Computers & Internet
How to fix Registration-Activation Error 0015.111 Autocad2010
The reason for this error is the product key u used. I mean autodesk 3ds max has FOUR different product keys 128x1 for 3ds max, 495x1 for 3ds max design, 774x1 for entertainment creation suite premium, 661x1 for entertainment suite standard.[x=A/B/C/D/E/F depending on the year].
so reinstall the autodesk product, use a different product key( Try all these four one at a time), one will definitely work.
same thing happened to me for maya 2014, but solved it using a different product key
Jan 02, 2013 | Autodesk 3ds Max 2010 for PC
The application preferences file is damaged. Please remove it and re-launch QuarkExpress [297] Where is the preferences file located? (Version 9, Windows 7)
The preferences file will be in the User\AppData folder.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 7 is the location in Vista with version 7 and it should have a similar location in Windows 7.
C:\Users\ your user name\AppData\ Local\Quark\QuarkXPress 9 is likely. (AppData has 3 folders - Local, Local Low and Roaming.)
You should not delete the folder. Instead rename it. Right click on the folder and select Rename. Then name it
old_QuarkXPress 9.
This could be a hidden file. If you click Start and then enter Show hidden folders. Then put the bullet on Show hidden files, folders and drives. Then click Apply and OK.
If moving the AppData location to another folder doesn't solve the problem, check if there is a Preferences file in the Program Files folder (
C:\ Program Files\ Quark\ QuarkXPress 7.x for the old version.) If the new version is built for the 64-bit OS, it might be in the x64 Program File folder. Again rename the file if it is in that directory.
I hope this helps.
May 14, 2011 | Computers & Internet
Whenever i start google chrome,it shows a message"whoa,google chrome has crashed,restart now?" please tell me,how to repair it.i have already reinstalled it,but same problem appeares......please...
Try uninstalling again, and after uninstalling, remove the 'Chrome' folder from the application data folder.
If you are using Windows 7, the folder will be located at:
C:\Users\(USER)\AppData\Local\Google\Chrome
Substitute "(USER)" with your user id. For instance, if your user id is 'Fred' then your folder would be at:
C:\Users\Fred\AppData\Local\Google\Chrome
If you are using Windows XP, the folder will likely be located at
C:\Documents and Settings\(USER)\Application Data\
Delete only the 'Chrome' folder, and not any other such as googleearth.
If you're unsure of what you're doing, you may also rename the folder to something like 'wasChrome', that way the folder isn't available to the future Chrome installation, but is still 'there'.
Once you've gotten rid of the Chrome folder, reinstall and this may solve all your problems.
Nov 11, 2010 | Google Chrome
Autodesk is not opening
Sep 03, 2009 | Autodesk 3ds Max for PC
May 22, 2009 | Autodesk 3ds Max for PC
good luck.
shafky
May 20, 2009 | Autodesk 3ds Max 9 Essentials
Autodesk 3D Studio Max, not Map 3D
I found the problem. I just had to change the view from Direct. It works fine now.
Feb 29, 2008 | Autodesk Map 3D 2006
Autodesk 3ds Max for PC Logo
246 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
