Sound problem with Standard (CRT) Televisions along with set top box
Sound is not coming in ELCOT TV. the TV is provided with Set top box. when disconnected from set top box and switched on AV mode also, only blue screen is coming, still no sound. Set top box supplier puts the issue on TV. cables are properly connected and the issue started with sound coming and going and one day fully stopped. Pls. tell me, whether the issue is in TV or in Set top box.
    Top Expert:
  • Televison & ... Master
  • 34,217 Answers
From your description, it is likely that there has been a failure in the TV sound system.
Posted on Dec 27, 2013
  • 236 Answers
SOURCE: no sound no picture.but when playing the x-box picture on and sound
I think your TV is in the A-V mode. The X Box is going into the TV through the A-V jacks. (AUDIO/VIDEO). You should be able to switch the set to tuner mode with the remote. Look for a button labeled input or go into the menu and look for "input". Stargazer
Posted on Sep 18, 2007
SOURCE: JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Posted on Oct 05, 2008
  • 85 Answers
SOURCE: Again, I don't know how to find the AV mode.
the converter that you have will only work thru the tv cabel. If you have a s-video you can use that for the picture but you still need to use the red and white audio cables for the sound. This converter will not give you HD but it will make the picture you recieve better. The picture will play thru your TV on chanel 3 or 4 and you need to use the remote that came with it to change stations. Hope this helps.
Posted on Feb 11, 2009
Maliron
  • 12 Answers
SOURCE: tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Posted on Mar 29, 2009
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
Is it analog or digital?
If it is a standard CRT TV unit it will be analogue only. If you want it to display a picture from a digital signal you will need to buy and connect a digital set top box to the TV. The set top box then picks up the digital channels through the antenna and displays the picture on the TV set. You will need the basic connections on the back of the TV to be able to connect a set top box and many older TVs do not have them..
Dec 26, 2015 | Televison & Video
Tv works on vcr, but when satellite box is plugged in to tv, tv comes on, hear sound for 2 seconds, tv shuts off . Why?
Check to see what video signal you are sending to the set from the cable box. If it is a HD signal set will not work - make sure it is a standard 480 signal.
Nov 30, 2015 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to tune channels on a 14 inch RCA tv?
You need a good set top box, either Hi definition or standard Pal, to make any CRT Television work. These days, non digital TV do work well but they no longer accept analog signals, but when connected to a set top box that receives digital signals, the box converts the digitals signals to analo and sends then to the RCA inputs of your TV and not via an antenna connected to the set top box and the TV.
Sep 01, 2014 | Televison & Video
Elcot tv model 27404 sound dead
elcot tv model 27404 sound dead.please give me solution
Regards,
R.kannnan
May 07, 2013 | Televison & Video
A black box keeps popping up in the middle of my tv screen and i have to hit a button for it to go away and it does it every few sec. and then will stop and wont do it for a while
The text function can come from one of two places;
This first is in the closed caption section of the TV set itself;
The second is (if you are using a Cable or Sat box) from a box providing signal to the set!
Most people think of the the problem just being in the TV when it can come from a box providing signal to the set.
SD TECH
Apr 09, 2010 | RCA F32650 32" TV
I have an LG Golden Eye CRT TV, is this compatible to a HD set top box?
well this tv dont have component inputs. u can connect hd set top box via a/v well picture will come but no hd experiance.....u have to buy a hd tv
Mar 24, 2010 | Televison & Video
When I plug my rca tv in it makes a high pitch sound,wont come on
The flyback transformer and the Horizontal transistor are not getting along. Take this set to the doctor.
Sep 04, 2009 | RCA F36650 36" TV
Audiosonic 51cm tv, will a HD set top box work?
nope standard def should though. will say tv does not support hd channels
May 29, 2008 | Sanyo DS27510 27" TV
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
