Konica Minolta Bizhub 350 error code c2211
IU Motor Failure How to reset ? many times I remove this code but . after some hours this code come back...
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
  • 300 Answers
SOURCE: Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
Posted on Sep 02, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Konica minolta bizhub c200 erroe codes c255c
Black Imaging Unit Failure.
remove-shake-and reinstall black IU
Replace IU-K, if not then PRCB faulty.
Feb 03, 2014 | Konica Minolta bizhub Office Equipment &...
C2557
C2557 ATDC Sensor Failure
• The scanning value of the ATDC Sensor is less
than 7 % while the IU Motor is turning.
• The scanning value of the ATDC Sensor is more than 19 % while the IU Motor is turning.
This is form the service manual, The meaning is developer material or the worst case you should change the entire ATDC sensor.
Jan 23, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c450 error code c-2555
Yellow Imaging Unit Failure.
Take out IU-Y, shake it, check the toner layer, Re install it.
and see if improvement, else remove IU-Yellow
May 06, 2013 | Konica Minolta bizhub C450P Laser Printer
Will not spin or agitate
Remove the front panel. Observe the motor flashes.
The motor blinks on and off all the time.
It blinks faster when running.
If a failure occurs you will get the following flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lid switch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes. If no light is visible you have a blown fuse built into the neutral side of the harness on the white/red wire.
themobilian_2813.jpgthemobilian_31.pngIf you see a small bubble in this black heat seal and the motor light is not on then the fuse within is blown replacement part is WH49X10041
What else do I have? Oh yeah how about the SERVICE MANUAL
Aug 12, 2011 | GE Profile WPRE6100G Top Load Washer
Code 11 come out from the led. The heater rinnai 556FTR doesnt work at all. Code no 11 is blinking. Thank you
A couple of things can cause a Code 11(Ignition Failure): The gas line at the heater is not turned On or not turned on all the way. Also an obstruction in the Direct Vent Termination.
According to the Owner's Manual:
If the appliance fails to ignite, the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. If ignition fails again, then the fault code will remain and another attempt to ignite will occur in 1 hour. The fault code is not stored in the fault code history.
If the flame is extinguished during forced combustion then the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. Forced combustion takes place for about 15 seconds after ignition. After this time, the temperature control logic controls the combustion.
If the flame is extinguished (burner combustion failure) while the temperature control logic is operating the appliance, then the appliance will immediately attempt ignition. No fault code will appear.
If the problem was not either of the 2 listed above, the electronics may need to be reset. You can do this by turning the Master ON/OFF Switch to OFF and unplug the cord from the wall outlet. Leave the unit unplugged for 15 minutes, then plug it back in and turn the Master ON/OFF Switch to ON. The electronics should revert back to the original factory settings. From there you can set them as you like. If the reset attempt fails, a service call by an authorized service technician is the next step.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 31, 2011 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Mal function detected. please call your Technical Representative c2557
ATDC Sensor Failure
The sensor in the developer unit has failed. In some cases this code will occur after a PM where the developer was replaced and calibrated but the developer or drum counter was not cleared. The reset for this error is to turn the machine off (unplug it) and turn it back on. If the error comes back you will need to replace the sensor and developer.
May 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Tha laptop just beeps when switched on. power ok, nothing on monitor - beeps 4 times then that is it!!!
4 short beeps might mean you have a bad memory module (beeps are coded) .. if you have two memories installed you can try takeing one out at a time .. it will start working when the good module is the only one plugged in .. just removing and replacing the memory sometimes cleans the pins so that it works again .. ... there are other possibilities that are more expensive usually ... so you hope its just the memory .. here is a site that gives beep codes for many machines ..
http://kb.iu.edu/data/afzy.html
Oct 06, 2009 | HP Pavilion dv6000z Notebook
Won't spin
The F51 error code flashes when there is a rotor position sensor (RPS) failure or lower harness problem.Here are some recommendations you can try to resolve this issue:
First disconnect the electrical power to the washer.
Make sure the basket turns freely. (By the way, make sure you are not overloading the washer. Make sure objects, and or clothing are not getting caught on the rotor underneath the washer jamming the rotor. Make sure you are not using too little water by using the wrong cycle for the type of load.)
Lean the washer back so that you can access the motor from the bottom then remove the rotor (1-bolt), and the stator (4-bolts). Make sure the stator and wiring harness have not been twisted causing the connector to twist at the RPS board creating a bad connection.
See image below for the RPS & harness location.
Unplug the RPS sensor connector and then plug back in 5-6 times to make sure if there is any conformal coating on the pins you cut through it and make good contact. Then tug back on the wires to make sure the connector bites onto the terminal and makes a good connection.
If you still have an F51 error code I would recommend calling a service technician to diagnose & repair.
Sep 02, 2008 | Kenmore Oasis HE 27082 Top Load Washer
1,442 people viewed this question
k24674
