Question about Fargo Persona M11 Thermal Printer
Cleaning head on hp photosmart 7760 printer
I have lost the instruction book for my printer (above) and find that the print head needs cleaning and don't know how to go about doing so.  Every other line is blank and I do have new ink cartridges in the machine.
  • Anonymous Mar 25, 2008
    I have the same issue. How do you fix it?
  • Anonymous Sep 08, 2008
    Me Too !!
  • 944 Answers
SOURCE: Cleaning the Print head
Here is the link to the user manual; Check page 181 for detailed instructions, page 179/180 for details of what you need to clean it. Hope this helps :)
Posted on Jun 26, 2007
  • 390 Answers
SOURCE: HP PhotoSmart 7760 InkJet Cartridges Stuck to the RIGHT.
What do you mean by foots sticking the cartridges, is it part of the printer, or the cartridge
Posted on Aug 16, 2007
  • 4402 Answers
SOURCE: cartridge failed after replacing it wtwice
unplug and plug back in?
are you sure you have the correct one in the correct slot?
Posted on Dec 21, 2007
SOURCE: bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Posted on May 05, 2008
  • 5 Answers
SOURCE: Pages come out blank instead of printing
try turning it off then back on....maybe that will work
Posted on Jul 01, 2008
Print is fading out. some times it is perfect but most print from my HP photo smart 7760 is a portion clear and gradual lightening to smudge like...
Hi Good day!!! Try to clean your print head
Please follow this step:
1. Turn on the computer and monitor. If using a Windows-based computer, click the "Start" button on the toolbar at the bottom of the monitor screen.
2. Move to "Settings," then "Control panel."
3. In "Control panel," look for "Printers and other hardware." Click on it. Inside this dialog box, you should now click on "Printers and faxes."
4. In the "Printers and faxes" dialog box, select the HP printer icon.
5. Using the right mouse button, click on the "HP printer" icon. At the bottom of the list, click on "Properties."
6. You should see seven tabs in this dialog box. To clean the printer heads, click on the "Services" tab. Under this tab, select "Align the printer cartridges" and "Clean the printer cartridges." For now, click on "Clean printer cartridges."
7. A new dialog box should appear, then click on the "Clean" button. The cleaning will now begin for the printer heads. This only takes about two minutes to complete. If you think your printer heads have not be cleaned well enough, do another test until the printer functions as it should.
8. Cleaning printer heads is something that should be done on a regular basis. Cleaning the printer heads will keep the printer from being ruined and causing unnecessary headaches.
Thank you for using FixYa
Please accept if my solution helps you.
Nov 18, 2010 | HP PhotoSmart 7760 InkJet Printer
My HP photosmart 7760 is leaking when it's printing. What could be the problem. Thx
leaking Ink?? defective cartriges take them back where you bought them and complain if they say no throw a fit and tell them you want your printer cleaned out also
Nov 30, 2009 | HP PhotoSmart 7760 InkJet Printer
I lost my software and cant print note come no
Go here for Drivers & other HP software for your printer:
Sep 04, 2009 | HP PhotoSmart 7760 InkJet Printer
Recently downloaded an driver update, printer stopped printing. using windows XP PRO OS. Lost the original disk software for the printer
You may have downloaded the incorrect driver. I would try using the driver directly from the manf. website. You can find the download here: DOWNLOAD
May 05, 2009 | HP PhotoSmart 7760 InkJet Printer
Lines on pics
Could be either or Both.
1:) Clean the print heads, using the printer toolbox et,c.
2:) Check the head alignment.
3:) check the printer rollers are in good condition.
4:) check the printers general settings, to ensure the settings are correct. paper type. print quality ( Draft-Text-Photo et,c )
Mike @ Compurepair.
Jun 22, 2008 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart 7760 InkJet Driver download error
are u trying to install it from the cd??? check whether that cd is supported for your operating system....
if everything ic right, then download the appropriate drivers from the website...
follow the link above and select the correct operating system and downlload the drivers and then try to install it
thanks and regards
Mar 29, 2008 | HP PhotoSmart 7760 InkJet Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
Poor photo printing
Have you manually cleaned the printheads. Bad clogs from different reasons sometimes cannot be removed by the printers own cleaning system. Use a good quality solution and thoroughly clean heads.
Jun 28, 2006 | HP PhotoSmart 7760 InkJet Printer
Fargo Persona M11 Thermal Printer Logo
872 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
