Question about Kocaso M M9100 9-Inch 8 GB Tablet
I push the power button the kocaso screen comes on and tells you injoy colorful life and then goes to a screen that said android for five or six seconds and then shuts off well it does not shut off it just goes to a black screen cause you can see blue lights on in side the charging hole and it beeps when you hit the volume button
    Master:
  • 193 Answers
I used this link and found it had a 50/50 chance of working...
http://forums.androidcentral.com/android-4-1-4-2-4-3-jelly-bean/347622-kocaso-m1066-tablet-system-ui-has-stopped-working.html
I know it's not for your exact model, but manufacturers often have the same method of hard reset for all of their devices. Specifically:
"The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen and you`re done."
Hope it helps u too
Chadman
Posted on Dec 27, 2013
My tablet comes on shows the lil android the goes to the green screen with the android
Do a hard reset, I can't give specific instructions as I don't know what phone you have but you can usually do a hard reset by either holding down the power and home button or holding down the power volume up and home button, at least those are the most common for Android tablets/phones.
Also try taking the battery out and putting back in (if possible). Good luck.
Aug 06, 2015 | Kocaso NEW MID M9000 9.0 " Android 4.0...
When I try doing a hard reset. I can not get it to boot beyond the green Android guy. It shuts off or will not get me to the choice menu. Any suggestions?
On an android tablet of mine I have to hold the power and the volume (-) button down at the same time and keep holding them for about fifteen to twenty seconds until finally a menu with green text comes up. To select the text option I want, I have to scroll with the volume (+) button and when I'm on the right option I have to activate it using one short push of the power button.
The option I choose to do a hard reset is *wipe data/factory reset*. On my tablet, when I choose and activate this option it takes me to another screen with about six lines of *no no no* text and one line of the reset option. I have to scroll to the reset option using the volume(+) option and again use a short push of the power button to activate it. Then, it does it's thing and turns off. I then give it about ten seconds and then I hold the power button down for five or so seconds and it then it reboots to factory fresh condition. It takes a couple of minutes to get it done I guess because it's reloading all the apps, etc.
Mar 28, 2015 | Kocaso M1050
What would cause my Kocaso M1050S tablet to be froze on the screen with android across it?
I had a kocaso tablet...M9100. After I Googled it, I found that Kocaso tablets are junk...bought a Google nexus 7...best on the market
Sep 14, 2014 | Kocaso M1050 10.1" Android Tablet PC with...
Kocaso comes on but only shows the word android
It is not loading the operating system, only the Linux starter program. try power resetting it.
you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Jun 04, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Touch screen is not working properly
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
This should reset the calibrations to default.
http://www.kocaso.com/troubleshooting.html
Mar 08, 2014 | Kocaso M766 Dual Core 1.5Ghz Dual Camera...
How to unlock passcode pattern on my android tablet kocaso m752
switch off your tab
hold up button
keep pressing power button multiple times
it'll show you hard reset setting
if not
then hold up and down simultaneously and keep pressing power button
reply me when you succeded
Feb 02, 2014 | Kocaso M752 Dual Camera Android 4.0 ICS...
Kocaso M736 is stuck on the Android screen
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Jan 23, 2014 | Kocaso M730w 12ghz 4gb 7 Capacitive...
Hi, i click the power botton ten open to the logo Kocaso then goes to the logo of Android green screen and stays there, before was working fantastic
HI, you have an android powered device and its stuck on the android logo when turned on :
1. you can try to go the manufacturer page and see if a full download for your device firmware/software is available and you can re-download that to your device - if possible
2. I am not familiar with Kocaso, so if there is a Hard rest button try to push that button for about 10 sec or more, so that you device can resets to the original (when you bought it) software (backup)
please note :::: both above solutions might or will delete everything on your device if its not backed up or have a memory card
this is non of my business, if anyone tried to root it (if possible for this model) than that could have been of the reasons this happened
let us know If this helps
thanks
Oct 18, 2013 | Tablets & eReaders
Kocaso Sx9722 The operating system will not come up.. Only the word Android
Use the firmware for SX9701 at the bottom of the page http://www.kocaso.com/support.html.
There are instructions to follow and you may need to use the Phoenix Card self extractor. Links are all on the same page.
Jan 23, 2013 | Kocaso Sx9700
Kocaso M M9100 9-Inch 8 GB Tablet Logo
223 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
