How to reset the samsung wa7584c1 + control panel
My washing machine returns the 1E error and its not the pressure switch. when i bypass it works but wants to reset it. How do i operate the control panel to reset. please help
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: My samsung automatic washing machine
Hello, the error code is due to a water pressure switch error the service manual says
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s also before replaceing the pressure switch assure that the tube that comes off the switch that connects to the tub on the tub end has no debris or soap build up inside the hose this could also make the switch show as an error if the hose had something in the end of it. Thanks again
Posted on Aug 23, 2011
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    It's showing an error message, 1E?
    The manufacturer has assigned the 1E error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve. This is the electrically operated valve that allows water into the machine when required.
    Jul 11, 2014 | LG LDF6810ST Stainless Steel Built-in...
    My samsung automatic washing machine wa7584c1 is giving me a 1E error why ?
    Rick
    Aug 23, 2011 | Washing Machines
    My samsung WA1065D1 toploader got a E1 please explain how and where I can fix that error?
    1E - WATER PRESSURE SWITCH ERROR
    The pressure switch should be replaced.
    Thanks!
    Dec 28, 2010 | Washing Machines
    HOW CAN I SOLVE MY PROBLEM BY MY SAMSUNG WA1065D1 , it shows 1E? When I switch it on after a few seconds it shows 1E? Can u please help me?
    Dec 20, 2010 | Washing Machines
    How can I fix the error code 1E in my washmaching samsung SW70A1P
    Error 1E is no pulse to weighing sensor to open and closed valve.
    Step to solve:
    1. Open top cover (behind door cover)
    2. Check connecting cable of pressure switch, pull out and clean up connector (usually dirty with rust)
    3. Open back cover, pull out pressure switch.
    4. Clean up hose of pressure switch, blow the hose slowly.
    5. install again pressure switch to the position.
    6. Install cable to connector, check the current & resistant by tester.
    7. Push "on" selector and fill drying position, wait until digital no blink. Running test.
    8. If machine is running well closed the cover.
    If still error condition (1E Error still come out), change part of "Pressure Switch" by the new one.
    Regards,
    Priyo
    Nov 16, 2010 | Washing Machines
    What is E no 1 on washing machine wa13G7Q1
    Hi
    Error code 1E means WATER PRESSURE SWITCH ERROR. This error occurs when the Generated Frequency Signal of water level is low or high.
    If the Water level is detected as low or high for more than 5 seconds, then it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 minutes after which you would get this error. To resolve this issue you can try and clean the filter screens inside the water lines. To check this disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back. This will resolve the issue.
    Daniel
    Sep 01, 2010 | Samsung Washing Machines
    Error code ( IE ) on my samsung washing machine model wa13g7q1
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
    Error message 1E is displayed at start up samsung model SW75C3S
    1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
    May 19, 2009 | Samsung SW62ASP Top Load Washer
    Washing Machines Logo
    54 people viewed this question
    Top Washing Machines Experts
