Question about Universal AULA BEFIRE USB 2.0 104-Key Backlit Gaming Keyboard - Black 180cm-Cable
Aula befire win7 driver
Dropping out since installing new graphics card
My gf9400 gt 1gb shows blue screen, until booting it works but while loading win 7 it crash dump blue screen appears every time???? but after plug out graphic card and plug in onboard vga works fine what...
Hello bsod often means you have a driver problem, or a graphic card problem.
The graphic card could have a defect, this can cause the blue screen.
Try also to check the device manager, for any other drivers missing.
Try first to download and install the newest driver from nvidia:
http://www.nvidia.com/object/win8-win7-winvista-64bit-314.07-whql-driver.html
This is the 64 bit driver.
The 32 bit is here:
http://www.nvidia.com/object/win8-win7-winvista-32bit-314.07-whql-driver.html
If i am wrong by my selection, choose another here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Or use Automatically find drivers for my NVIDIA products, by installing a small bit of software.
If the driver update does not help, the graphic card must be renewed.
My advice is to uninstall ALL the old nvidia software, before you install the new.
Are the onboard graphic nvidia ???
This can sometimes create a conflict, when the graphic card brand are the same.
Try to disable the onboard graphic, in the device manager.
Good luck
Mar 05, 2013 | InnoVISION Multimedia Technologies Inno3D...
I want to install my palit geforce 210 1gb ddr3 on my desktop with win7 & 3gb ram, model of cpu is aspireM5600. The problem is, when I installed the vdeo card driver and it requires to restart the
Using onboard graphics enter into the BIOS and set the setting to display to PCI-Express first then onboard if noexist PCI-E graphics.
Save and exit.
This will allow you to install your new graphics card to your monitor.
Take care!
damnor01
Sep 11, 2012 | Palit Microsystems Palit nVidia GeForce...
The drivers of my video card (Asus EAX850XT 256mb) seem to prevent windows from starting up. when i load on to 'safe mode' and i uninstall them and restart my PC it loads windows but then will try...
hi names Rui
it mean you video driver is not compatible with you win7 64bit OS just try to download video driver for 64bit. i think the driver that you installed are for 32bit only i will not work on you 64bit OS ok.
Jul 20, 2011 | ASUS EAX850XT/2DHTV/256MB PCI EXPRESS...
On my Computer's Gigabyte-Board i have a Winfast A180BT graphic card. It works ok even with Windows7-x64 standard driver. Only thing is when i tried to do cam-chat with with my friend Windows...
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html This package consists of SiS VGA Drivers, AGP Drivers, VGA Utilities, and Installation for Windows 7. Utilities include Control Center and SiStray. The Control Center provide some settings like gamma correction, video, TV output, driver mode, screen rotate, and product information. The SiStray provide Control Center entery and some settings like resolution, refresh rate,and rotation. The Installation are capable of installing/uninstalling drivers and utilities respectively.
Supported Chipsets:
SiS671, SiS672, SiS671FX, SiS672FX, SiSM671, SiSM671MX, SiSM672, SiSM672MX hope this helps cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
hope this helps
May 08, 2011 | Leadtek WinFast A180 BT GeForce MX4000...
My ACEDV capture card did not work at windows7
this card is incompatible with windows 7. however you can download it's windows 7 driver.
if you couldn't find it install it's win xp driver.
Jan 09, 2011 | Canopus ACEDVio Graphic Card
Can i install this card in win7 if yes from where i can find its driver for win7
the drivers of this card can only support operating systems xp , 2000 , linux , vista 32 or 64 bit..
not for win 7...
Dec 20, 2010 | Jaton Video 228PCI-Twin GeForce FX5200,...
Need drivers
For this video card you can get the driver for win 98, me, or xp from here:
http://www.amd.com/us/Pages/AMDHomePage.aspx
on right side, download drivers, choose from drop lists:
component cathegory: graphics operating system: xp -- or -- win 98, me product line: radeon product model: radeon 9250 series
then press on view results and you will get a new page with the download link for
catalyst software suite x.xx
No drivers needed for Windows vista or windows 7. Since this is and old card it is not directly supported from manufacturer, but ussually vista or win7 will install automatically a generic driver that allows you to use the card. Might need to change resolution and color dept after installing on vista or win7.
Good luck on setting up your card!!
Apr 15, 2010 | GeCube RADEONĀ® 9250, PCI Video Card
Hi i have a KT4V motherboard and recently got a radeon 9800 pro graphics card - and upgrade form a radeon 9250 (which worked fine on xp but when i upgraded to windows 7 it wasn't supported). when i first...
Yes and No. Let me explain. You have taken an older board that worked with XP and tried to make it work in Win7 (which is not supported by the board). Add in your graphics card switch, and you have a real mess.
You can upgrade your motherboard (for one that is compatible with Win7 - (ie. a brand new model with Win7 certification) and use a graphics card that is also Win7 compatible, or
Go back to a configuration that worked
Dec 16, 2009 | MSI KT4V (MS-6712) Motherboard
Universal AULA BEFIRE USB 2.0 104-Key Backlit Gaming Keyboard - Black 180cm-Cable Logo
1,430 people viewed this question
Top Universal Computers & Internet Experts
Dan Shibata
Dan Shibata
tech you
tech you
 Russ Hill
Russ Hill
Are you an Universal Computer and Internet Expert? Answer questions, earn points and help others
