Question about Cuisinart DGB-500 Coffee Maker
Cuisinart Coffeemaker DGB 500
Our grinder is no longer lifting out easily so that we can clean if after use. There are times we literally have to pull this free from the coffee maker. It's as if the grinder blades do not let up from the grinding process. I am afraid we will end up breaking our unit over this. Any ideas?
  • 1 more comment
  • eldon354 Sep 01, 2008
    Similar problem only worse. Grinder basket extremely hard to remove. We have cleaned well several times, but still sticks in. Almost as if grinder blade base is wedged, bonded, or stuck to the post that turns it?
  • victorjohnst Nov 26, 2008
    grinder basket is stuck in the coffee maker and will not come out. will I break it if i force it some way?
  • Anonymous Mar 25, 2014
    I can lift the coffee machine off the counter and the grinder base will not come out.
I had the problem also.  First, I cleaned the area very well of the caramelized coffee gunk. where the grinder goes.  I also filed away a few degraded areas on the grinder's plastic housing.  Haven't had the problem since.
Posted on Oct 29, 2007
  • Barbara Pearson Oct 21, 2012
    Thank you! I had to pry it out with a spoon handle. then washed it THROUGHLY! I didn't grind it out but did put a bit of veggie oil on it just to grease it up a bit.
SOURCE:
What is stripping the young leaves on my runner beans
This is a problem with your Cuisinart Grind & Brew Coffeemaker? This product uses roasted whole bean coffee. Why in the world would coffee beans have leaves attached? Makes no sense.
Jun 16, 2014 | Cuisinart Thermal DGB-600 Grinder
Brewed coffee overflowed on to warmer plate. Now water does not heat and flow and warmer plate does not heat up.
Unless it is an expensive brewer, get a new one. The brewer needs the bottom plate to heat in order for it to work at all. Should be imune getting wet though, but sounds like bad heating element.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Cuisinart Model DGB-550 Coffeemaker...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
I cannot remove the grinder from my cuisinart Grind and Brew Coffeemaker. It still makes great coffee, but I want to clean the grinding mechasim and cannot remove it.
Common with the DGB-600 - you can try icing it down for 10 minutes - once removed, clean exterior with vinegar applied to a rag to get oils off - endemic to this unit - replacing it with exact same model will not help.
Oct 13, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart dgb-500 automatic grind & brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Jun 11, 2008 | Cuisinart DGB-500 Coffee Maker
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
May 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-500 Coffee Maker Logo
355 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
