Question about Vehicle Parts & Accessories
Weel bearing replacement on 1990 vw carevelle
Detailed descripsion and parts needed for the replacing of the rear weel bearing on a 1990 vw ceravelle
  • 60 Answers
You didn't say whether it has disc or drum brakes on the rear but either way it shouldn't be a difficult job for someone with basic mechanic skills. If it has drums in the rear it is as simple as removing the outer dust cap, remove cotter key holding the lock nut in place then remove the grease seal on the inner side of the drum and wipe as much of the old grease as possible. Then the bearing races that the bearings ride on will need to be replaced, this can be difficult and dangerous so wear proper eye protection while using a long drift punch or flat tip chisel to drive the old races out, there are cutouts on the area around the race and you will need to go from side to side until they are out. Replacing the races is just a reverse order ans the race with the large opening down you will want to use a chisel laid flat across the race and carefully tap into position then use the flat end of the chisel to drive the race down until it is seated all the way in the hub taking care not to damage race and keep the safety glasses on. Then it will be packing the bearings with specified bearing grease, and installing new bearing seals and re installing hub and wheel. One other thing I advise all of my customers is to buy a repair manual for your car, they can be bought at most car parts stores or online from various publishers such as Haynes or Chilton for about $20 USD this is a very small price for most everything a consumer can service on their car.
Posted on Jan 01, 2014
O8 srx rear weel bearing replacement
Please follow this video link to the Cadilliac owners forum for a full tutorial of the job of replacing the rear hub assembly. I know it is a 2002 year model but it is the same procedure.
Oct 12, 2012 | 2005 Cadillac SRX
Where is the clutch release bearing on a 1997 vw jetta
It is located on the transmission input shaft collar of the transmission inside the bell housing.
Sep 07, 2012 | Cars & Trucks
Trying to remove and replace the right rear wheel bearing on a Hyundai xg 300 2001 model
you have to remove the caliper first than your disk brake(this is a hub assembly) on the back of the weel bearing you should have 3 big bolts remove them put a chain on 2 of the stud of the weel put back the nut on them (if you don't have the tool to do it)than take a steel bar and do like a (slege hammer) just few hit it should come out!..hope this will help you. lipak!...
Mar 29, 2010 | 2001 Hyundai XG300
Replacing front wheel bearings on 2002 new bettle
how to change rear wheel bearing on vw. beatel 2002 1.9
Dec 18, 2009 | 2001 Volkswagen Beetle
My weel bearing keeps going out in the driver side front
The wheel bearing is not being replaced correctly or parts that need replacing are being left on the car. Here is detailed instructions on how to replace the wheel bearing on a Taurus which is the same as a Sable. http://autorepair.about.com/library/faqs/bl029i.htm
Dec 17, 2009 | 1997 Mercury Sable
Repair rear '67 Beetle suspension
1967 VW beetles had a type of trailing arm suspension, which gave some amount of independence between the two sides. The axle tube, with brake plate and bearings, coming from the transaxle, attached to the trailing arm suspension. The only part that normally had to be replaced in the rear suspension were the shock absorbers. In 1967 they were NOT Macpherson struts, so they are just bolted on and easy to change.
Nov 02, 2009 | Volkswagen Beetle Cars & Trucks
Fan motor to light is humming
this noise is most often not the fan at all but the color weel motor.
start pricing color weel replacment for your model
a good parts place is www dot parts store dot com
Jan 11, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Vehicle Parts & Accessories Logo
43 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
