Question about MSI Computers & Internet
Benq vad6038 dvd rom
I need the wiring schematic for the vad6038. the placement of the motor wires and white switch wires.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • MSI Master
  • 2,226 Answers
Get a new one easyer
Posted on May 19, 2014
5 Suggested Answers
SOURCE: i need a diagram showing placement for the case power switches
I have the same problem like shoesteve, by that link is not work at me. Please post a link if someone know other site. Thanks for eventualy help.
Posted on Oct 30, 2009
  • 336 Answers
SOURCE: CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Posted on Aug 22, 2009
  • 2666 Answers
SOURCE: do i need a third wire for the dvd rom and where do i plug it on
No just data cable and power
Posted on Oct 03, 2009
supertech6
  • 513 Answers
SOURCE: i need the order for placing wires black in place.
The wire placement is usually written small right on the motherboard. Each front panel connector should be labeled.
Here is the owner's manual for the motherboard:
http://download.intel.com/support/motherboards/desktop/d815eea/EA_ENGLISH.PDF
(Hint: Copy the whole link to notepad, make it all one long sentence, copy again and past into your browser)
Posted on Mar 22, 2010
Testimonial: " my late husband gave me the CP it did not come with manual or I can not find anything written.I am sorry if that sounds odd."
Xbox trouble
Better off going for a replacement DVD as you may never get the drive motor to function normally. Timing is important and alignment super important.
Jan 03, 2014 | BenQ Vad6038 Dvd Drive Motor Spindle Xbox...
New pentair dynamo pump 115v need to wire a cord to the motor
see side of motor for schematic low voltage move wiring or turn switch to 120 volt then black to L1 white to L2 green to ground or case
May 25, 2012 | Pentair One - Speed 1hp 115v Dynamo Pump...
Hello: I have a Levitron White decora 15 amp combination switch: I need to get a copy of the schematics as someone threw the schematics away... Geesh! Note The MFG part number is the same as the...
Hello.
There is no schematic shown online for that specific product.
Leviton shows a spec sheet on their website but no wiring schematic.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?sitex=10026:22372:US&item=8938
However the spec sheet does show the screw terminals on one side of device that indicate this is ordinary combo switch-outlet.
Open following link for illustration of combo switch-outlet:
http://waterheatertimer.org/images/Combination-switch-outlet-6.jpg
The problem that usually confronts people when they replace light switch with combo is that the combo requires additional neutral wire to power the outlet.
Neutral wires are the white wires twisted together and covered with wire nut that are pushed to back of electric box. Connect a short piece of white wire to the neutrals, and connect that wire to screw on combo device. If your electrical box does not have these neutral wires, you can get the outlet to work by using bare ground wire instead of white neutral, but I would never recommend this action as it violates national electric code and would not pass home inspection and would cause risk to electrician working on that same circuit who was unaware of a code violation.
Jul 23, 2011 | Leviton White Decora Rocker Switch &...
My x box 360 keep saying open tray every time I put a game disc in.what can i do?
Pop off the faceplate look inside the hole on the lower right side
of the cd rom drive if you see a yellow and white wire is a Dg-16d2s Philips
they cost around 35-40.00 new on ebay . If it's two white wires it's a BenQ VAD6038 6038.
Same price. Order it from ebay goto youtube and type" Xbox 360 drive replacement "
When your drive arrives remove the P.C. board from the old drive and plug/solder it
in the new one and it's fix . This is a sure fire-way to get your drive working.
option 2 . is to buy a laser for a ben-Q drive 20.00 and simply swap it out
but this work about 60% of the time since the spindle motor and worm gear motor
will some time be the cause .
If you have any questions please ask before you rate this tip.
Thanks
Rob
Mar 26, 2011 | Microsoft Xbox 360 Console
Need som help with a wiring question on a CD#52 AO Smith 1/2 hp blower motor. the furnace runs wiring for a white, red and black not sure which wires go where.
Look at the schematic on the inside panel of the cover you removed. It should have the schematic with the wires and colors labeled as to what goes where. The wires are a common, run and start wire. They schematic should identify the wire by color and motor connection by number. You should be able to see the numbers on the motor by the connection. hope this helps.
Jan 29, 2011 | Heating & Cooling
Game console will not read disks
Usually the LASER which you can find on ebay for about £10. It is very easy to replace yourself but you will need to know what DVD player is in your console (i.e. Benq, Samsung, Hitachi etc) and it's model number so you will need to take it apart which again is pretty simple. There are many tutorials on this found through Google or on video with You Tube.
Enter the model into the Ebay search box (i.e. BENQ VAD6038 LASER) and click search.
I'm in the UK so seleted 'UK Only' in the search options so I don't got to wait a year for it to arrive and I selected 'price from low to high including postage'.
Try and select a seller with a yellow ribbon 'PowerSeller' status as they tend to want to keep good feedback scores on post things on time and well packaged.
My search found this result: http://cgi.ebay.co.uk/New-Xbox360-replacement-Benq-laser-HOP141x-VAD6038-UK-/370222670077?pt=UK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN&hash=item5632fda0fd
That will be just the job for that drive and is a cheap fix. Remember this is not hard to do. Just be patient, calm and confident. I have seen a 12 year old do this and fitting instructions usually are supplied. If not Google or You Tube again.
Please rate if this helped.
Oct 31, 2010 | Microsoft Xbox 360 Console
I need to wire my DJ-20 Jointer back to 230 and I don't have schematic Suggestions?
Assuming you have a standard dual-voltage single-phase motor, your wire colors should be:
T1 - Blue
T2 - White
T3 - Orange
T4 - Yellow
T5 - Black
T8 - Red
For 220V wiring, you want:
Line 1 (to Black wire from switch):
Blue
Black
Line 2 (to White wire from switch):
Yellow
Tied together with a wire tie:
Red
Orange
White
This should make it so the shaft spins counter-clockwise. If you need it to spin the other direction, switch the red and black wire from the motor.
Jun 23, 2010 | Delta X5 Dj20 8" Precision Jointer
On My Delta DJ-20 Byrd head Jointer I don't have a wiring schematic to switch it back to 230 previous owner had it wired for 110. Any suggestions besides calling Delta to send me Schematic
T1 - Blue
T2 - White
T3 - Orange
T4 - Yellow
T5 - Black
T8 - Red
Blue
Black
Yellow
Red
Orange
White
Also, don't forget to change the wiring the switch. Most likely you will need to run both the black wire and white wire through the switch.
I need schematic for motor controller be. weslo
If I make no mistake the controller has marking for the wire placement. Look closely at the connection, it should give you a color code.
Nov 17, 2009 | Cadence Exercise & Fitness
I wired a new dura-glas pump as a 115, and it popped the breaker. I put the black wire on 1 and the white on 2. Should I have wired it as 230? Should I switch the black and white wires, even though the...
The wire placement does not matter assuming you have a 115 volt supply with a three wire cord/cable and they are comming in as blk=hot, white=neutral and copper=ground.
Tripping a breaker would be from a shorted hot wire so look for a place where it touches the white or ground wires or the metal of the motor. Another cause would be if you really have 230V across the black and white and you connect it to a motor set for 115V. Is the breaker that turns off the circuit in question a signle wide or a double wide breaker. A double wide would be 230V.
Jul 31, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Computers & Internet Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
