Question about PNY 16 GB USB 2.0 Flash Drive
Lexar usb stick cant get memory back
Have 16gb stick,had photos on it put photos in trash but did not get memory back and cant reformat on my mac
When I put in 16 GB Maxell memory stick into my MacBook Pro it does not acknowledge it. The package says it is compatible with MAC but this one is not working.
Try reformatting on another computer in a more compatible format. Also try to find in the finder and right click and look into the formatting options.
Dec 12, 2014 | Maxell 16GB USB Slider 2.0 Flash Drive...
Lexar 16GB S73 appears as Innostor NAND Flash USB Device
can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Dec 09, 2013 | Lexar Media Jumpdrive S73 - Usb Flash...
How do i use a memory stick on computer
An example on how to safe documents , photo's or data to a usb drive Click start all programs accessories open windows explorer navigate to your photos
Right click on the documents , photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them
or if you are downloading data or programs from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
If you need more help with this post a reply
Mar 21, 2013 | Lexar LJDS70-16GASBNA 16GB JumpDrive S70...
How to unlock a lexar usb
Hey mate u can reformat this drive or there's a program vcwipe u can download its free it wipes any drives
Oct 22, 2012 | Lexar Echo ZE 16GB USB Backup Drive Hard...
I reformat my memory stick and now the camera don't recognize the card, what can i do?
Reformat with camera. iOS / Mac has different file allocation table (structure).
Oct 01, 2012 | Sony 4GB Memory Stick PRO Duo Memory Card
How do I put photos from my comuter onto a 2gb sony memory stick
  1. Insert a Memory Stick into the Memory Stick slot in the left side of the PSP. Depending on how many photos you want it to hold, you may need to get a larger one than the stick that came with your system.
  2. Turn on the PSP.
  3. Plug a USB cable into the back of the PSP and into your PC or Mac. The USB cable needs to have a Mini-B connector on one end (this plugs into the PSP), and a standard USB connector on the other (this plugs into the computer).
  4. Scroll to the "Settings" icon on the home menu of your PSP.
  5. Find the "USB Connection" icon in the "Settings" menu. Press the X button. Your PSP will display the words "USB Mode" and your PC or Mac will recognize it as a USB storage device.
  6. If there isn't one already, create a folder called "PSP" on the PSP Memory Stick -- it shows up as "Portable Storage Device" or something similar -- (you can use Windows Explorer on a PC, or Finder on a Mac).
  7. If there isn't one already, create a folder called "PHOTO" inside the "PSP" folder (on newer firmware versions, this folder may also be called "PICTURE").
  8. Drag and drop image files into the "PHOTO" or "PICTURE" folder just as you would save files in another folder on your computer.
  9. Disconnect your PSP by first clicking on "Safely Remove Hardware" on the bottom menu bar of a PC, or by "ejecting" the drive on the Mac (drag the icon into the trash). Then unplug the USB cable and press the circle button to return to the home menu.....
hope this helped..good day..please vote...
Dec 11, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
How do I empty the Lexar memory stick to create more room?
if you have moved everything off it, just right click and choose format.
You can do this from my computer, or disc managment (right click my computer/manage/disc managment)
Jul 10, 2010 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Can't connect psp 3000 to mac with USB cable
Try reformatting the memory stick. If that does not work he can try to connect just the memory stick it self ( may need an adapter) to the mac and formatting it there. Other wise you may need a driver for the PSP.
Jun 08, 2009 | Sony PSP-3000 Silver Console
Lexar jumpdrive
its simple ( i dnot have a mac)
go to applications and select Disk Utility and select ERASE !!
that would do the job dear !!
Mar 07, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
PNY 16 GB USB 2.0 Flash Drive Logo
29 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
