Panasonic TH-L32X10A VIERA Television. No HDMI shows when press input
Input selection does not show HDMI
  • 4 Answers
SOURCE: panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Posted on Dec 30, 2008
SOURCE: Panasonic Viera TH-37PX70 Pedestal Stand
i need the instrucation how to install the pedestal stand
Posted on Mar 10, 2009
SOURCE: Auto Switch does not work for HDMI inputs
Try this:
http://www.avforums.com/forums/6539544-post3094.html
Posted on May 17, 2009
radar001
  • 1051 Answers
SOURCE: HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Posted on Dec 17, 2009
  • 15 Answers
SOURCE: viera link pop up problem...ANNOYING
You need to (either or both) change from Shop setting to Home, and turn off Viera Link demo.
Go into the menu, choose set up and re set to shipping settings.
Posted on May 29, 2010
How do I get to my HDMI channel?
It isn't a 'channel' it is a connection port. Once a cable box or DVD / blue Ray player is plugged into it, you choose the port using the Input button on your remote and scroll through them.
That set has 2 HDMI connectors on the back panel, right side, more or less by themselves, to the lower left of the antenna jack.
See the link. In the cluster of 3 photos, click the center one, then zoom it. Source(s): http://www.crutchfield.com/S-QWOJIeQP36Y... kg7or ยท 4 years ago
All the info on the television including manuals and inputs can be found here,
ftp://ftp.panasonic.com/television/howto/combo_connections_howto.html
58 Class 58 0 Diagonal 1080p Plasma HDTV with Anti Reflection
Jan 01, 2016 | Panasonic Televison & Video
How to connect viera link
What is Viera Link? Viera Link allows the control of other Panasonic home AV devices via the television remote control.
By pressing the Viera Link button on the television remote, it is possible to turn on and navigate the menus of other Viera Link equipment. Please note, Viera Link requires an HDMI connection between the television and the external source.
More control functions have been added with each new generation of Viera Link compatible products. However, it is important to note that the newer functions only work if both products are from the same year of manufacture. Therefore, if an older source is used with a newer year of television, only the older functions common to both years will work.
Aug 26, 2014 | Panasonic Viera TH-42PX80U Plasma TV
I'm trying to plug my ps-3 to my panasonic viera th-50pz80u with an AV multi-out but i have no signal. No sounds, no images. Please help me
In your PS3 configuration you'll likely have to set the PS3 so that it is using the multi-AV rather than HDMI.(In Video Output Settings) Also on the TV input you'll have to select composite in rather than HDMI.
https://support.us.playstation.com/app/answers/detail/a_id/788
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Hope this helps,
Jeff
Nov 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Tv not picking up hdmi input
HDMI is goofy. Connect everything while it is off and then power everything up. That should take care of it after the first time you do it.
Apr 19, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
TH-50PX77U inputs
Many times a computer's post screens will not show up a TV set, and once the computer itself has loaded the drivers and settings, the set may need to be shut off and turned back on for the HDNI or PC signal to be detected.
It is also possible the settings you selected for display properties cannot be displayed on the TV.
As far as the component video signal, are the connections correct? Sometimes people mistake the composite red, white and yellow for the composite system that divides the red, blue and green video signals.
While also possible, but rare- there may be poorly soldered connections on the "A&D" board (logic board) .
Jul 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Trying to set up Panasonic TH-L32X10A LCD TV. Have plugged into the wall and the screen display says 'No Signal'. How can I fix this? Thank you.
chose the input from the lcd operation on screen manual that is proper for the signal you are using (example) hdmi, AV, or TV. when you choose the correct input selection the lcd will show what ever signal you are sending it.
Apr 18, 2011 | Televison & Video
I have a panasonic Viera and I'd like to play my computer through it. The computer picture works fine through a converter to the HDMI cable input but how do I get sound? I need a separate cable from the...
does your computer graphics card have a hdmi output on it? i had a same problem the coverter input will not let sound though it u would need a hdmi output from the computer or need to connect a separated sound output as the form of speakers from the computer itself, i mite be a problems with drives, try updating the graphics card drives. this mite solve the problem as well. hope this helps
Aug 13, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
