Question about Zanussi ZWF1420W Front Load Washer
My beko wmb81221ls drum will not go round - Zanussi ZWF1420W Front Load Washer
Beko washing mc leaks when it goes into rinse cycle water drips from bottom right model 7164
it could be leaking from the filler and going round the bottom of the drum or the feed pipe. check the seals can assess the bottom seals with out taking the top off. turn off washer and unplug cable and pipes. tip washer on side to gain access lower pipe is drain feed and right is breather pipe and door lock sensor line. if you need to take the top off as the leak is on the filler screws on back. then pull back and lift up the top. check the pipes and case on the filler tank. replace top in reverse order.
Jul 17, 2017 | Beko Washing Machines
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
Beko WMI71641 won't agitate or spin - drum doesn't move!
your pump is blocked,at bottom of machine there should be a flap with a round plug in middle .unscrew,it will have water come out so use a bowl or big towel.the impeller should turn freely,once plug is unscrewed at front put washer into a drain program see if the pump turns.if this is free youll need to get the pump off(unplug machine first)and then feel inside the big pipe from the drum to pump.it may have a sock or something like inside.this means it will work but wont get out all the water.also note when trying to spin a pillow,or big towel the load will be uneven so it will reduce its spin speed so it doesnt destroy its self
Apr 16, 2014 | Beko WMI71641 Built in washing machin
Water leaking from outer plastic drum on beko washing machine found 2 small hole what is the best thing to stop leak
A poxy plastic sealant but you may get lucky call around get a good used drum at a repair shop.
Mar 05, 2014 | Beko Washing Machines
Drum outer softerer tub plastic
Check with Beko for availability of the part you need to replace
Aug 21, 2013 | Beko WM5140W
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
I have a new machine beko wm 5120 W and tried to re-spin some items after they had been through a wash cycle...i turned the dial to spin, chose my spin speed and pressed start...the machine went through a...
No idea why but it happens to us to. You need to cancel the wash, switch off and leave a few mins then retry, not that it may work.
Now the spin cycle has stopped on ours too plus the spin is not actually working, drum is just going round and round slowly! We've had it just over a year so the guarantee has finished too :-(
Oct 31, 2010 | Washing Machines
Beko washer
have you tried the brushes on motor
Jan 02, 2008 | Washing Machines
Zanussi ZWF1420W Front Load Washer Logo
15 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
