Question about DeLonghi Coffee Makers & Espresso Machines
Error door not closed - DeLonghi Coffee Makers & Espresso Machines
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Close door
Posted on Dec 29, 2013
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Error code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Jun 19, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
'user door open' error -where is the 'user door'? We have opened and closed all the parts we can find that open and close.
the door you open to put the cartridge. If the door is closed and you still get the message, it means the door is not activating the microswitch when the door is closed. There must be a tab on the door which presses the switch.
May 22, 2009 | Dell 1815dn All-In-One Laser Printer
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Coffee Makers & Espresso Machines Logo
73 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
