Question about NCR Computers & Internet
Communication fatal - NCR Computers & Internet
My phone shows fatal error message and wont function
take it to where you have your service, they should be able to help
Mar 03, 2015 | Verizon Communications Cell Phones
Fatal error 231 error 3
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
Jul 17, 2014 | OKI C6100n Laser Printer
How can I fix oki c3530 231: fatal error 03?
PCB.
the RFID reader.
chip.
Jun 21, 2014 | OKI C5800Ldn Led Printer
Oki
231 means RFID reader I/F error. 03 means Communication error
between the RFID reader and the tag chip. The remedial measure is to check for normal connection of the antenna cable.
May 06, 2014 | Oki Electric Industry C830DTN Laser...
Fatal error hardware p98-25
P-98-025 is a communication with the RFID meaning the supplies RF "sticker" not being read by the machine. There are 2. One inside master tube and one you can see on the ink tube , 1" Half round with fine copper lines. The communication is a fiber optic cable which could be loose. The easiest one to get to is behind front drum cover .
4 screws and look for a 1/4 inch cable plugin. Hope that's the one
because this can be a tough one to troubleshoot.
Nov 26, 2013 | Riso RZ220 Duplicator
Vertical lines on a pansonic tv model # TC-P5OS1
Bad Panel----this is fatal cost wise.
Bad connections where ribbon cables connect panel to boards.
Communication problem in the set between main digital board and other boards.
May 16, 2012 | Televison & Video
Showing 121: fatal error
It is not exactly "fatal", it is related to LSI power supply or disturbance in it communication with high-voltage LSI chip, try this solution first:
1. switch off the printer and remove cord from power supply, remove network connection as well.
2. switch printer on (without power!) for 20sec, switch off
3. connect power supply, and switch printer on
4. connect network cable
If this operation did not clear the error, unfortunately you need to service the printer.
Hope this will help to solve your problem, please leavenote how did it go.
Aug 17, 2010 | OKI C5500n Laser Printer
231 Fatal Error 03 means what
chip... THATS THE CHIP IN THE TONER CARTRIDGE
Jan 10, 2010 | OKI C5500n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
SERVICE CALL 188 : FATAL ERROR
Service Call 188: Error: Sub-CPU Communication Error
1- Check the connection of the S2M board.
2- Replace the S2M board.
If the problem does not go away after a reboot you'd better call Oki (it should have a 3 yr. waranty) or an experienced oki technician.
This is not something you should want to fix yourself. The replacement of the s2m board is not an easy task (even for an experienced mechanic)
Jun 24, 2008 | OKI 9800hdn Laser Printer
Computers & Internet Logo
Top NCR Computers & Internet Experts
John Hong
John Hong
Are you a NCR Computer and Internet Expert? Answer questions, earn points and help others
