Question about Gateway MD2614u Notebook
Why does vehicle dies when you disconect thebattery
    Prodigy:
    An expert who has answered 500 questions.
  • Gateway Expert
  • 510 Answers
What does this have to do with PC laptops ???
Posted on Feb 11, 2014
1994 honda accord new altanator ,engine dies when battery is disconected
If the alternator is wired correctly and working,the vehicle will keep running if nothing else is switched on at idle speed.
Just because an alternator is new does not guarantee it works.
Make sure the alternator has a connection to the battery (voltage at it's output terminal) and has power to it's regulator.
May 27, 2017 | Honda Cars & Trucks
Battery dopes not hold a charge
How old is the battery? Does the car sit for long periods of time? Or is it an old battery with the vehicle driven only short trips? If thebattery has died many times and you have charged it. It more than likely has a dead cell. The issue with this is it will still read 12v when connected to a battery charger making you think the battery is good. Walmart will test for free, plus they have cheap batteries.
Nov 12, 2013 | 2006 Ford Five Hundred
2005 dodge caravan, instrument panel stopped working and so did my turn signals and brake lights
from having a died battery the body control module goes into back up mode from a low battery so disconect the battery for 5 min that should reset it
Oct 14, 2012 | 1999 Chrysler Sebring
Checking alt. on 2002 ford focus ;disconected battery cable car died.wondering if car dies even if the alt. is good
Removing the battery lead is an old trick and does not work on newer vehicles. Take it to an oreilly auto parts and have it checked for free! :)
Jun 20, 2012 | Cars & Trucks
2002 ford explorer battery died and after jump start it will not start due to something with the security system... the doors lock and unlock and the car makes this loud clicking noise
Sounds like the battery cables need to be cleaned and or maybe thebattery is getting ready to die. Clean the battery terminals then charge the battery. If the terminals get real corroded it is usually indicated by the clicking sound you have described. Hop it helps and good luck.
Dec 08, 2010 | Code-Alarm Code Alarm Transponder
When excelerating powere died and then stalled out
Check for spark, use a spark tester that can be purchased at an auto parts store. If you have spark get some either or starter fluid and spray it into the throttle body...you will have to disconect the air intake from air filter. If the vehicle starts, the fuel delievery is at fault. If the vehicle doesn't attempt to start at this point, I would assume that you have lost a timing chain. If this proves to be the case, the best approach to this is to find a junk yard trany since debrie usually goes all through the motor and it is cheaper this way. If you don't find any spark, you will want to look for codes that might be present. They will lead you to the fix.
Mar 01, 2010 | 1996 Saturn SL
I stored my car for a year and thebattery wentdead, when i puta new battery the amp didn't work.the green light comes on, but no sound
when you started up the vehicle after a year you most likely "surged" the amp. Check the fuses at the battery and at the amp. Most likely you will find one or all blown.
Aug 01, 2009 | Car Audio & Video
Smoke coming from throttle cable when ignition is turned over???!! Huh??? Multimeter also reading continuity across the battery terminals...
It would seem that you have a pretty bad short. I would follow the throttle cable to see what source of power it is shorted to. I would also recomend disconecting thebattery till the problem is found.
Worst case senario is that a fire starts and somebody gets hurt.
May 16, 2009 | 1991 Toyota MR2
Gateway MD2614u Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
