Question about Numark ttUSB Turntable
Replace blown fuse - Numark ttUSB Turntable
Fix blown fuse on KGRA 806PSS oven
Check the fuse if it blown replace with new one
Sep 13, 2014 | Microwave Ovens
Cigarette lighter fuse volvo
Find your fuse block, remove fuses 1 by 1 , replacing each that you find is ok with the original. (no need to replace a fuse that is still good) untill you find the blown fuse. Replace the blown fuse with a new one. A blown fuse looks like this:
ALL BLOWN FUSES WILL HAVE A BREAK IN THE MIDDLE SIMILAR TO WHAT IS SHOWN ABOVE. needle nose pliers works very well. This procedure will not take no more than a couple minutes.
Dec 05, 2013 | Cars & Trucks
Indoor pcb fuse has blown
look for a small glass tube fuse and set your meter to ohm and see if it rereads a value if it doesnt it is blown take the writing on the fuse and replace with same fuse if in doubt or you dont have a meter just replace it they are cheap
Feb 13, 2013 | Heating & Cooling
HP LaserJet 4200 F2 Fuse Blown
Replace the power supply. Sorry.
Jan 09, 2013 | HP LaserJet 4200dtn Printer
2001 330ci 5 speed wont start found blown starter fuse replaced still nothing what should i check next?
look around the starter fuse. the blown starter fuse could of effected something around it or something else could of caused the blown starter fuse.
Aug 14, 2012 | Dell Inspiron 1018 Notebook
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
2005 suzuki xl-7 12v acc outlets stopped working
if the fuses were blown they were blown for a reason. Check the fuses again and make sure they havent blown again. Likely there is a wire touching something it shouldn't
Apr 21, 2010 | 2001 Suzuki Xl 7
Headlights and door locks not working
Fuse is probably blown out. Replace fuses for respective functions. Find the fuse box: might be in engine near battery or below steering wheel. open top and check for blown fuses. Try replacing if blown fuses are found. If all fuses are OK then it is very unlikely that all the bulbs are blown.
Jul 23, 2009 | 2004 Chrysler PT Cruiser
Numark ttUSB Turntable Logo
29 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
