Question about Audio Pro 15PLB76 15 Inch 800 Watt Woofer Car Speaker
I HAVE A 2004 CHEVY IMPALA AND MY SPEAKERS KEEP BLOWNING AND NO SEEMS TO NO WHY.WHAT SHOULD I DO NEXT TO FIX THIS PROBLEM.
Try checking the crossover on the factory preamp
Posted on May 18, 2009
2004 chevy impala solenoid stuck open
The solenoids are inside the transmission.
You may need a book and some special tools to make the repairs.
Jul 10, 2012 | Cars & Trucks
Im trying to locate the relay to the power windows on a 2004 chevy impala
check under the hood in the junction box or next to fuse box under dash
Mar 18, 2012 | 2004 Chevrolet Impala
My 2004 Chevy Impala only blows cold air with heat on. The heater would only keep it a little warm the other day but now only seems to be blowing cold air.
Check in the main radiator with the motor cool that the coolant is full as if the coolant is low there will be no heat in the heater. If it is low you need to check for leaks or head gasket problems. If its full check that the temp guage is coming up to its normal position as the thermostat could be faulty. Then make sure that the heater tap is operating corectly.
Feb 27, 2011 | 2004 Chevrolet Impala
My 2004 chevy impala has a engine code of PO455 and i changed the gas cap but i keep getting the code back. any thing else i should check?
Sometimes the recirc line fitting can be cracked or worked loose and allow the same pressure loss. On the Impala I am not exactly sure how to get to them.
May 07, 2010 | 2004 Chevrolet Impala
Fuse F6 in trunk compartment on my 2004 Chevy Malibu keeps blowing. This fuse provides power to the front and rear parklamps and also the backlight on the instrument panel cluster. The blowning fuse...
Yes it could definitely be related to a bad dimmer control. You have a partial short to ground somewhere in your dimmer control circuit. Pull the dimmer control and measure resistance to ground at the circuit connections.
Aug 19, 2017 | 2004 Chevrolet Malibu
My 2004 chevy impala low pressure tire light
remove the tyre valves and fit normal ones ,then the lights cant work and you have one less thing to worry about
Apr 11, 2009 | 2003 Chevrolet Impala
Reman starter not working quite right
The best wiring diagram you can get ahold of is from your local chevy dealer. The eyelets on the wires for the starter should only fit on the appropriate studs. If you can't get some help from the dealer head for your local parts store and see if they have a manual that can help.
Mar 15, 2009 | 2004 Chevrolet Impala
I smell gas in the interior of my chevy 2004 impala what would cause this?
a fuel leak somewhere in your engine compartment. if you can't find it and fix it..get it fixed professionally ASAP! that can get dangerous very quickly. the leak is flowing into your ventalation system through the hood then up into the cowel vent at the base of your window. keep your vents closed and drive with your windows rolled down until its fixed.
Mar 14, 2009 | 2004 Chevrolet Impala
Car Audio & Video Logo
306 people viewed this question
Top Audio Pro Car Audio & Video Experts
xxxxxx xxx
Are you an Audio Pro Car Audio and Video Expert? Answer questions, earn points and help others
