Question about Panasonic NV-VX37 Mini DV Digital Camcorder
Panasonic vx37 My panasonic vx37 camera goes on but it says camera and a red light goes on when i push the button so that it goes to vcr the light does go green but when i want to record it just goes back to camera mode and the red light goes on how do i fix this? and even though the battery is fully charged it goes of in about 5 minutes.
  • werner_boers May 18, 2009
    thank you, but when i push record button it switch to camera mode and then it doesn't want to record
    Problem Solver:
  • 7 Answers
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
Posted on May 18, 2009
SOURCE:
Universal Remote code for 60 inch plasma panasonic 60ps34?
Hello
Setup codes with universal remote control with Panasonic TVs are:
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search Method
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Sep 18, 2011 | Panasonic Televison & Video
Need a four digit code for comcast universal remote for panasonic th-42px80u
Hello
Four digit universal remote codes for Panasonic TV are:
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Mar 27, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Need remote control code
Hello
Three digit universal remote control code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote control codes for Panasonic are:-
Four digit unversal remote control code for Panasonic TV/DVD/VCR combo is
0437
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
Direct Code Entry
OK.
Dec 02, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
I am looking for the direct tv remote code for tv model PVQ-M2509 Panasonic Omnivision VHS como.
Hello
Four digit universal remote code for Panasonic TV-VCR combo are:-
0374 0381
Three digit universal remote code for Panasonic are:-
Direct Code Entry
Nov 25, 2010 | Panasonic PVQ-M2509 Combo
Panasonic camera md 9000 it has reset problem
you have problem with socket cylinder head..you can't repair this problem, you must bring camera to panasonic service center
Jul 01, 2009 | Panasonic NV-MD9000EN Mini DV Digital...
Panasonic NV-VX37 Mini DV Digital Camcorder Logo
264 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
