Question about Mitsubishi Heating & Cooling
Mitsubshi Heavy Aircon fan coil uit auto on issue
The Mitsubishi Heavy Air Conditioners ACM-SCM60ZG-S purchased a few years ago gave me probem very recently. The fan coil unit could be on by itself and kept blowing the maximum strength wind. Remote is unable to off it (remote works properly). Need to switch off the main switch to stop it. Any input is appreciated in advance.
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
SOURCE: AC not working
Try opening the front of the machine and check the circuit board has not got anything on it the could cause a short. I had the same problem but mine was a gekko that fried on my circuit board.
Posted on Apr 14, 2009
  • 10865 Answers
SOURCE: unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
Posted on May 25, 2009
  • 534 Answers
SOURCE: outside unit fan not turning no cold air inside.
Ok here we go. It is possible that the capacitor for that fan unit is out or the motor for that unit is out. Without the proper tools i.e. an electrical meter, there isn't really a way to test the unit. The remote should not have anything to do with the unit activating if the is a manual thermostat. I suggest checking to see if either the motor has gone bad or the capacitor has bit the dust. If you have the motor changed make sure to replace the capacitor
Good Luck on your repairs hope I helped you some\
Dave
Posted on Jan 08, 2010
Testimonial: "A very quick response with a helpful reply. "
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
1994 mitsubishi lancer aircon problem..is it possible to change the mitsubishi aircon motor to nissans aircon motor?
best talk to an a/con technican as there is a size/capacity requirement for compressors. While it may be feasable to fit another compressor it needs matching tx valve condensor and evaporator to work properly. He should be able to tell you if it will work or not
Jan 27, 2013 | Cars & Trucks
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a 2003 Mitsubishi Lancer. A few weeks ago when I turned on the air I could hear like a rattling in the fan. Now the air will run for a little while then slowly weeken until it just stops. What could...
It could be your aircon blower that's busted. I had the same issue with a 97 Lancer. It was the motor of the blower that was defective so I had it replaced. Never heard the rattling noise and the A/C works perfectly fine after the replacement.
HTH and good luck!
Apr 19, 2011 | Mitsubishi Lancer Cars & Trucks
No Mitsubishi Air Con Manual
ok heres the problem. The a/c filter is clogged or the evaporator coil is clogged. These systems have a metering device that measures the amount of air flow over the coil. If this air flow is obstructed the filter light will flash. If the filter in the unit is clean then the coil has some type of obstruction. This will mean having to clean the coil before the light will go off. An a/c tech should be able to clean this for you and it not be a huge cost. They have the chemicals to get the job done fast and clean.
Change your filter first.
Good Luck hope this helped you some
Dave
Jan 12, 2010 | Mitsubishi MS15TN Air Conditioner
Ice forming on front coil of aircon blower
the front coil or evaporator is not absorbing heat from the conditioned space or the condensing coil or back one is not rejecting heat. usually this is due to dirty coils or clogged filters
Nov 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Goodman fan running but no air coming out of vents and temp is now 85. Also, is there a restart button on the machine
you have to chaeck if the outdoor unit is running you the t-stat has to call for cooling in turning closing contacts between r and y the pulling in coil at condensor. your outdoor unit is not running
Aug 17, 2009 | Goodman CLQ36AR49 Air Conditioner
My aircon is freezing up its only 6 years old. the furnace is old old not sure how old though. I noticed that the drain hose from the furnace was plugged can that cause freeze up?
The condensate drain must be clear, otherwise there will be a lot of moisture in the coil area. If there is not enough air flow the coil can freeze -check filters are claen and fan is working properly.
Jun 16, 2009 | Heating & Cooling
Inside house is warm
Use the spell check and please restate your issue. Have you checked your air filter? Has the unit been serviced recently?
Sep 04, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
18 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
