Question about Pool & Spa
Hurlcon chlorinator keeps tripping safety switch
5 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Safety switch at top of heater keeps tripping.
Somewhere short circuit or loose wiring.Check wiring and rectify.
Posted on Jan 06, 2011
kel1guy2002
  • 3740 Answers
SOURCE: keeps tripping the safety switch
Hi and welcome to FixYa, I am Kelly.
If you had a momentary power loss this symptom will present itself. Try unplugging the unit for 30 minutes and let the coolant system and compressor stabilize. Then see if it starts. If it does start great. If it does NOT start I need a make and model number to better help you troubleshoot. With that information I can provide how to steps and parts information applicable to your refrigerator.
Thanks for choosing FixYa,
Kelly
Posted on Mar 23, 2011
Cloudkicker
  • 18 Answers
SOURCE: my low salt light on
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Posted on Jul 06, 2011
tracy89266
  • 57 Answers
SOURCE: The fuel safety switch keeps tripping, when I shut my sport trac off, this switch is designed as safety feature when in a collision.
blow out canister vent lines with compressed air, check for any obstructions, spider nest, dirt etc. The vent line is at the rear by the filler neck going to canister vent solenoid then to tank. Check the filler neck for damage, if all looks ok, check the inlet check valve to tank for sticking condition.
Posted on Mar 05, 2016
How to take the fan cover off the Hurlcon cx240
might not be fan check safety circuit
Apr 09, 2018 | Pool & Spa
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
Rool out switch keeping tripping
assume you mean roll-out switch on a furnace....it is a temperature sensitive safety control intended to limit the temperature in the vestabule or burner area. if it keeps tripping, it's because something is causing the temp to get too high. a dirty filter would be first suspect. it could also be an inoperative blower, a dirty evaporator, or a blocked flue or vent pipe. check all these things out and you will likely find your problem..
Jan 27, 2013 | Heating & Cooling
I have a newly installed pump (1 month old) it is tripping the breaker.
If your pool has a salt water chlorinator and the salt level is too high then it could trip the circuit breaker as the combined load from the salt water chlorinator and pump motor exceeds the circuit breaker rating.
Jun 12, 2012 | Hayward Pool & Spa
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
Hope this helps.
Jul 06, 2011 | Grilling
My dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
Pool & Spa Logo
62 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
