Question about Samsung HCN5527W 55" Rear Projection Television
65' MITSUBISHI Projection TV - Picture bows - looks 3D
We have a 65' MITSUBISHI Projection TV purchased in 2001.  About a year ago the picture started to bow.  Looks 3D like and distorted.  Anyway, I want to sell the TV now and want to fix the problem before I do so.  Can someone tell me in laymen terms how to fix the problem?  I heard it was a color converter that needed to be fixed…very costly fix.
Thanks for any help!
  • Joe1974 May 11, 2010
    Sounds like a convergence problem. The convergence chips most likely have failed. They are usually referred to as STK chips. I don't have any experience with Mitsubishi TV's but this tends to be a common problem with CRT projection sets. It is also hard to diagnose without seeing pictures of the problem. I can tell you that the site that Jean posted will not fix this
    problem and could even make things worse. That site pertains to a specific problem that is common in
    some Sony sets and should not be used to try to fix any other issue.
    Please keep in mind many things can go wrong with TV
    sets and you should really do a lot of research before attempting any
    adjustment and or repair. There are high voltages present in some areas and they can
    reside even when the set is unplugged.
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This Link goes to a Blog , that covers problems like this and other Picture/Color problems.
Any one with this or other Projection TV Picture problems ( any Projection Brand or Model )
should try this !! SIMPLE NO COST !! solution.
It covers easy instructions , with pictures :D Must mention tho, the instructions and pictures will be for a Sony Rear Projection HDTV (High-definition 16:9 aspect ratio , model KP-51HW40 but like I said, this solution covers MANY different Makes and Models.
Worth a try ;)
Hope this helps YOU and other Consumers with your or similar problems !
Let me know and if it does make sure to share this blog with anyone who needs support on this issue ;)
This Guy Ken who posted the blog is just a consumer like you and me, who had this problem like MANY MANY others and went out of his way to help others.
Would like to see him get as much credit for his efforts as possible, yeah even if it just a thank you....he deserves it.
Couldn't post a thank you to him , for some reason it wouldn't go thru but this is my way of thanking him ;)
Enjoy your day !
Jean
Posted on Mar 12, 2009
    Sergeant:
  • 395 Answers
Convergance amps need replacing. check with a local repair shop for pricing. dont be shock it may cost ($350.00)
Posted on Jan 01, 2008
SOURCE:
Picture is distorted
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2011 | Mitsubishi WS-65313 65" Rear Projection...
Picture Bowed towards the center
It is a convergence problem, probably one of the convergence ICs has blown and must be replaced. Call the number in the last pages of your user manual to get repair service in your area.
Jul 25, 2008 | Mitsubishi WS-65413 65" Rear Projection...
My Mitsubishi WS-65313 picture lost it's red. things that are supposed to be red are purple. Any idea what is going on and do you think I can repair it? Thanks, Russ
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Mitsubishi WS-65313 65" Rear Projection...
Its a 2004 and picture isn't real clear what can be done?
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
Feb 24, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Picture is distorted, kind of looks like a 3D image without the 3D glasses.
Please do us a favor and rate this solution after reading.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 31, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi HD 65 is10 years old. The picture is bowed and the
Sorry you are having trouble.
This is very common problem.
Do you feel comfortable looking inside with the power off?
Most likely the lenses and or mirrors need to be cleaned.
For the mirrors we use Windex or similar cleaner
For the lenses I recommend lens cleaner from a camera shop
Yes this worth fixing. If you dont feel comfortable doing the cleaning yourself just call a serviceman
Apr 04, 2010 | Mitsubishi WS-65513 65" Rear Projection...
73" REAR PROJECTION MITSUBISHI STARTED DOING 3D
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 21, 2010 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi 290p080020 big screen tv
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 30, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WS-65807 problems
You need the two convergence IC's replaced part# STK392-570. About a $300-$400 repair.
Aug 23, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Samsung HCN5527W 55" Rear Projection Television Logo
146 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
