Question about Dryers
Whirlpool tumble dryer
The red warning lights stay on and will not tumble dry
    New Friend:
  • 33 Answers
I don't know much about Whirlpool, but do you need to empty the water/fluff filter or clean the condenser?
Posted on Dec 27, 2013
gittos73
  • 244 Answers
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Posted on Aug 15, 2007
textonor
  • 130 Answers
SOURCE: Bosch Tumble Dryer Filter Light
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
Posted on Feb 03, 2008
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
rogrrabbit
  • 986 Answers
SOURCE: Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Sep 12, 2009
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
Where is the filter on tumble dryer AWZ241
Hi Angie, The filter is at the back right in the middle, You pull the cover off and clean off the lint.........CHEERS..
Apr 27, 2016 | Electrolux IQ-Touch EIMED55IIW 27"...
When you power off the unit, it goes from bright led to low light led and shows a red light staying illuminated. Which means its STILL drawing battery. How do you turn it off completely?
Brake Hydraulic System Red Warning Light - RepairPal
repairpal.com/brake-hydraulic-system-red-warning-light
If the brake hydraulic system red warning light comes on and stays on, this indicates... and seems to come on and off depending on whether the vehicle is turning, ... if it is discovered that the light was illuminating due to a low brake fluid level.
Sep 10, 2015 | Cars & Trucks
Why does the red light on my VF70 freeze r stay on all the time?
Warning light (red)
If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food.
Dado
May 05, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Need to find out what a warning light means. dont have owners manual
It warns you that something in the engine or within the car needs attention. The warning light is usually yellow in color. Example: low gas warning-light. It will stay 'on' till the problem is fixed. You could sdrive the car, but be aware, be warned!
If a red light comes 'on', it indicates something improper has happened, needing immediate attention. An example is a door that was not fully closed. This red-light also will stay 'on' till the problem is fixed.
Dec 16, 2009 | 2001 Chrysler Sebring
No tumble action, belt seems fine
the belt has to be replaced
May 12, 2009 | Dryers
Kenmore dryer
check the heatingelement and the element high limit thermastat
the high limit thermastat is on the left side of the element housing and has two red wires connected to it
with a ohm meter the element and the thermastat will read contunity
i wuld start there
Apr 20, 2008 | Dryers
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
102 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
