Question about Vehicle Parts & Accessories
1992 bmw 325i door lock schematics
I have a 1990 bmw 325i and the button for the trunk lock stopped working...i checked the fuse etc. Someone pulled out the cylinderk but I don't see how to manipulate it. There is nothing to push or turn etc. How do I get in? can I take out the backseat and drill a hole in the wall and actuate the lock that way? drill from the outside? I can always patch it. The car is kinda beatup anyway
  • louis
    louis Dec 29, 2013
    thankyou for your help. I found out from my locksmith friend that you can take the license plate off and drill s small hole in the center of where the tag goes and insert a small screwdriver and actuate the lock open.
  • 39 Answers
I am not familiar with BMW at all. Earlier domestic cars trunk could be accessed with a flat screwdriver when the cylinder was removed. Get a flashlight and look in the hole to see if there is a slot oolong like a flat driver will fit. If so, insert the driver and turn right until it clicks/pops/snaps. It may take a bit of pressure. Again I say I'm not familiar with BMW but I hop this helps.
Posted on Dec 29, 2013
3 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: working on a 2002 Cavalier
Have you tried disconnecting the battery and letting it sit for about 15 minutes. Let the BCM reset. The lock being unplugged may have corrupted the BCM.
Posted on Jan 14, 2011
perkins48
  • 14363 Answers
SOURCE: broken trunk womt open eather by latch or key
Can you remove back seat and go thru there with flaslight and open from there.
Posted on Aug 07, 2012
HOW MANY FUSE BOXES ARE THERE FOR A 2005 BMW 325SI
Interior Fuse Box Location: 1999-2006 BMW 325i - 2002 ...
www.carcarekiosk.com/video/2002_BMW_325i_2.../fuse.../replace
Some BMWs have multiple interior fuse boxes including in the trunk - the video above ... If your 325i has many options like a sunroof, navigation, heated seats, etc, the ... to be replaced or if there is a short or some other problem with your 325i.
Fuse box location for 2005 325i? - Bimmerforums
www.bimmerforums.com/forum/showthread.php?...Fuse-box...2005-32...
Oct 28, 2014 - Does anyone know where the fuse box(S) located on E46 (325i) 2005? ... Bimmerforums - The Ultimate BMW Forum - Powered by vBulletin. Help. Remember ... Notes on removing Fuse Box...
Oct 26, 2014
2004 BMW 325ci fuse box schematic
Jun 16, 2010
Fuse box layout
Apr 10, 2007
Headlight fuse location help
Oct 30, 2006
More results from www.bimmerforums.com
Nov 23, 2015 | BMW Cars & Trucks
WHERE IS THE FUSE BOX INSIDE OF 1992 BMW
Check fuse if all the buttons not working ,should be under bonnet or under dash,if some work check buttons on switch panel.
Jun 06, 2014 | 1992 to 1995 BMW 325i Power Window Switch...
Bmw 1995 325i
It's unkiely that all the door actuators are bad. The problem sounds like a voltage loss to the circuit. Check the fuses for the door locks.
May 21, 2014 | 2001 BMW 325i
Is there a fuse for the trunk release button for a 2003 bmw 325i
Yes there is a fuse for the trunk opener.also,do you have a valet switch to shut it off?
Aug 28, 2012 | Cars & Trucks
How to program a previously used bmw keyless remote for a different 2006 bmw 325i
1) Get in and close all doors.
2) Turn on the ingition and turn off quickly. (No more than 5 seconds) to start the process. Next action must take place within 30 seconds.
3) Remove the 1st key.
4) Hold the key up near your left shoulder (this is so it is closer to the remote reciever antenna - someone else suggested this).
5) Hold down the unlock button (which is button 1 on my key) and press the lock button 3 times (center button on my key). Release the unlock button and the doors lock which confirms the operation.
6) Quickly repeat steps 4 & 5 for key #2 etc.
If it does not work, try doing the keys in opposite order. Key 2 then key1, vs 1 then 2
Jul 14, 2010 | Cars & Trucks
2006 BMW 323i Passnger Door lock will not lock / unlock w/ remote
Replace fuse 57 (15 amp) then disconnect battery and wait 30 to 45 minutes before reconnecting the battery.
My 2006 BMW 325I had the same problem with the door locks not responding. I checked all related fuses and found #57 (15 amp) was the only related fuse blown. I put in a new fuse and it still would not work. I then disconnected the battery for a while then once I reconnected the battery everything worked fine.
I believe I blew the fuse while repeatedly pushing the unlock button rapidly while walking across the parking lock to the car. I suggest only pushing the unlock button only once or twice.
Jul 28, 2009 | 2000 BMW 3 Series
2006 bmw 325i remote only unlocks driverside door. will not unlock all doors when you lock it from the inside. have to use key in remote to open door. also central button to unlock doors is inop
fuse 56 and 57 control central locking,the issue is caused by surges typically in the front door lock actuators, normally at a dealer they would replace fuse 56 and 57 with a 20a mini fuse and if still occuring repl the door lock(s) that dont work or typically both front, first replace fuse 56 and 57 with 20a fuses as were too small from factory and than operate ten to 15 times, if it doesnt work at first dont panic,let the car go to sleep which takes about 16 min and than try again this problem has nothing to do with the key fob or the lock unlock button inside,also the fuses are located behind the glove box just rere the access panel and they are found at lower left section
Jul 23, 2009 | 2006 BMW 3 Series
I have a 2001 BMW 325i. It started with the rear light display on the dash came on but nothing was wrong with the rear lights. I checked the fuses and nothing was wrong. Now the locks don't work. Only...
The connector on the rear lights gets burnt and you have to replace the connector, the burnt wire, and the taillight assembly. For the locks it could be a few things. Does the central lock button work all the doors? Does the remote function work with any doors, or trunk? Could be anything from the driver's door lock actuator to the general module for the car. If you have a scanner to check the ZKE module and code "general locking, unlocking relay" is there then a new general module is needed. The relays are built into it.
Jun 20, 2009 | 2001 BMW 325
I cannot find the fuse for window lift for 1992 BMW 325i 4-door.
There is no fuse but it has a circuit breaker. I changed the comfort relay and everything is working. spent $28.00.
Jan 05, 2009 | 2001 BMW 325
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
