Does anyone know how to switch from external to internal vga on notebook using hotkeys? acer aspire one notebook
  • flossy1973 May 18, 2009
    Hi thanks but still got black screen :(
  • 560 Answers
Fn + F3
Posted on May 18, 2009
  • Liza Halbrook
    Liza Halbrook May 19, 2009
    shutdown your laptop, remove projector/external monitor, turn it back on. you should get a display on your laptop's LCD, if not, you may have one of these problems: bad LCD, backlight or inverter.
I want to know what functions do all the keys on the top row of my keyboard do
<Fn> + <F1> = Hotkey help = Displays help on hotkeys.
<Fn> + <F2> = Acer eSettings = Launches Acer eSettings in AcerEmpowering Technology.
<Fn> + <F3> = Acer ePower Management = Launches Acer ePowerManagement in AcerEmpowering Technology.
<Fn> + <F4> = Sleep = Puts the computer in Sleepmode.
<Fn> + <F5> = Display toggle = Switches display outputbetween the display screen,external monitor (if connected)and both.
<Fn> + <F6> = Screen blank = Turns the display screenbacklight off to save power.Press any key to return.
<Fn> + <F7> = Touchpad toggle = Turns the internal touchpad onand off.
<Fn> + <F8> = Speaker toggle = Turns the speakers on and off.
Nov 11, 2013 | Acer Aspire 5733z Laptop/notebook
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an Acer One netbook and tried to connect it to a projector but the normal looking lead from the projector did not seem to fit. The lead has those two wee screws at the side, and no place for them...
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
I am not getting the screen to display stuff from my computer . I don't know if I hooked it up correctly, I need a walk through.
Double check the connection. Once you are sure that the cable is properly connected and the cable itself is not damaged, you may need to switch the output on your portable PC, assuming that is what you are using, based on the icon. If it is a notebook PC, they often have a switching hotkey command that is used to switch output of video between internal display and external displays. Try that... Also, make sure that the external display is capable of displaying the resolution your PC is sending, as this can also cause it not to work.
Sep 26, 2009 | Acer Aspire One PC Notebook
How do i hook up a bigger monitor to my laptop i have an acer monitor with a vga hookup and i have attached it to my laptop which also has a vga hookup i have been told to use the function keys but i can't...
One of the # or "F" keys should have a picture of a monitor on it, have you tried them all? Also, this can be achieved through the desktop properties in Windows, last tab, Settings.
Jul 09, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
Acer Aspire One Screen Wont Work!!
try hooking it up to an external monitor using a VGA cable. If you see something on the external monitor, then it's the screen that's bad, if you still see nothing, then it's more than likely the video card.
Mar 08, 2009 | Acer Aspire 3100-1405 Notebook
Multiplay display
check all the video cables in good condition? (VGA), then plug in the projector, and go to your laptop, on the desktop, right kick, if you can see 2 displaies ,LIKE SHOWING BIG # 1 AND 2........
Jan 12, 2009 | Acer Aspire 3690-2196 Notebook
Hotkeys doesnt work
just install the hotkeys driver from the acer website and they should work again! ^.^
Jul 12, 2008 | Acer Aspire 5630 Notebook
Address of acer service center in patiala
Watch out that you haven't switched off the screen by accident. One of the function key combinations toggles between the built-in screen and the VGA socket on the back or side panels to allow the use of either an external monitor or video projector. The key combination toggles three ways: 1) internal screen, 2) external VGA, or 3) both. On my Acer Travelmate 2200, the key combination is <Fn> + <F5>. Please try this first.
Nov 12, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
