Canon ir7200 error code 830
  • 41 Answers
SOURCE: Canon Mp 830 Noisey
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
As far as the noise goes (and possibly related to the error code) be sure that your scanner is UNLOCKED...
With the machine turned OFF:
Open the document cover, look on the tray where the glass is -- and then look to the LEFT side of the glass and you will see pictures of an opened lock and a closed lock and a little switch...
Make sure the switch is next to the UNLOCKED position.
WAIT 5 seconds or so and then turn the unit back on.
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 22, 2008
solofixya
  • 34 Answers
SOURCE: canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Posted on Nov 11, 2008
SOURCE: error code 5110 canon mp 830
Replacing the cartridges is the most common problem
Posted on Nov 24, 2008
tunmun
  • 413 Answers
SOURCE: HOW TO FIX ERROR CODE
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Posted on May 11, 2009
bschilz
  • 2049 Answers
SOURCE: I have a error code
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Posted on Oct 16, 2009
How to solve the problem of canon it 7200 error code E000246-0001
Canon Ir 7200 Service Manual Pdf - WordPress.com
https://crocynsuti.files.wordpress.com/.../canon-ir-7200-service-manual-...service is one manual of the 7200 free most the impending hazards canon due to 7200free imagerunner ... Error Codes _ Canon _ iR7200 _ Code E121-0001.
Jul 16, 2015 | Canon Office Equipment & Supplies
Canon ir7105 error codes 000602
TRy this link. Reading similar errors, similar machine = hard drive error. can ir7200 602 001 Archive Copytechnet com
Apr 09, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
Canon ir 7200 error code 732-001
hello i have problem with canon ir7200 error code 732-001
Aug 22, 2012 | Office Equipment & Supplies
Canon ir7200 error code list
IR7200 - EROOR CODE IS 67, PLS HELP ME
Feb 11, 2012 | Canon imageRUNNER 7200 Copier
Error code 354-0002 ir7200 serial number pcb
when you changed the main controller for the copier did you use the counter board that was on the old main controller or did you put the counter board from the old one on the new one.... if you don't use the old counter board with the new main controller then that problem will occure
May 19, 2010 | Canon imageRUNNER 7200 Copier
Error Code 19 for Canon ir7200
The waste toner case is full, or the waste toner case full sensor is faulty.
try empty the waste toner, if that doesnt work try clean the sensor
Sep 03, 2009 | Canon imageRUNNER 7200 Copier
I am getting error code E000019-000 on my old Canon Ir7200 imagerunner printer. Need help to fix it. Thanks.
Error E 019 is for the toner waste bottle full. It is behind a rectangle shaped cover on the lower right side of th machine (by the power switch). Empty it and reboot the copier.
Jul 27, 2009 | Canon imageRUNNER 7200 Copier
Explain error code E329 in Canon IR7200
not in manual
if this is correct code contact canon main dealer for advice
Jul 10, 2009 | Canon imageRUNNER 2870 Copier
143 people viewed this question
jasbo
jasbo
