Question about NetGear DG834G Router
My main computer has internet connection but my wireless computers can find my netgear but cannot connect
Check my all connectivity
Posted on May 18, 2009
Main router is a dlink, and it's connected to a netgear router as a slave, and i want to use the netgear router for wireless within the house
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 28, 2012 | NetGear WGR614 Wireless Router
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
Set up my netgear router. laptops show that they are wirelessly connected to the main computer, but we cant get them to connect to the internet. also lost the netgear cd that came with router. do we need...
The netgear router installation will set up the internet connection during install.
Download the Router driver from netgears website and install on the computer/s then your up and running.
it appears you wireless card is seeing the router so just install the drivers and your set.
Oct 03, 2010 | Computers & Internet
One netgear router for 2 computers
Dear Friend,
Try enabling the DHCP mode of your netgear router in order to give automatic ips tou your computers.After you have done so, configure your ip table in every computer in automatic mode.That should do the work.
Good Luck!
Jun 23, 2009 | NetGear WGR614 Wireless Router
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
My netgear will not let me connect to the internet via my wireless connection my main computer has internet as it is connecter via the yellow cable to the netgear my other computers have a netgear adapter...
Open Zonealarm, choose Firewall, Zones.
Add >> IP Range set your IP range eg 192.168.0.1 to 192.168.0.254
This should allow connection between Router and Wireless Laptop/Desktop.
If your wireless PC cannot see the router, check your router setting to see if you are transmitting a SSID
May 18, 2009 | NetGear DG834G Router
My main computer has internet but my other computers in the house cant find my netgear but windows cant connect
It sounds like you are using Windows Zero Conguration, go into advanced properties and de-select "Allow Windows to configure my wireless connection". Then you need tpo find your wireless utility that comes as part ofd the installtion for your wireless adapter and use that instead. On your laptop it is probably going to be Intel Pro-Set Wireless Configuration Utility.
Try that.
Gadget
Wireless adapter on 2nd computer is not connecting to my router
you put in the usb port then install the driver then you find it the wireless icon will came in the task bar right hand side in bottom then you right click on it then you got the option view viable networks click on it then you got the your ssid name just connect it then surf it
May 13, 2009 | NetGear WGR614 Router
Can't get it to work
I had the wireless working with dynex card before the virus hit the computer. The virus is fixed, but the internet does not work.
Feb 28, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
NetGear DG834G Router Logo
43 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
