Question about Hipstreet Flare 9 inch Tablet with 8GB Memory and Case
Unfortunately, launcher has stopped - Hipstreet Flare 9 inch Tablet with 8GB Memory and Case
The launcher has stopped
go to launcher, stop it and clear data and cache. Exit the settings menu and restart.
http://forums.androidcentral.com/asus-memo-pad-hd7/357082-unfortunately-launcher-has-stopped.html
Jul 07, 2016 | Tablets & eReaders
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
Jan 01, 2016 | Polaroid Tablets & eReaders
Why has launcher stopped working?
launcher stopped working Tablets & eReaders Questions ...
www.fixya.com > Forum > Tags > launcher stopped working
Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
Jan 26, 2014 - 22 posts - ‎17 authors
... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
[Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
forum.xda-developers.com/showthread.php?t=2069137
Dec 27, 2012 - 9 posts - ‎2 authors
Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
Error 'Launcher Has Stopped Working' ' Android Tablet Forum
Dec 12, 2015 | Tablets & eReaders
How can start tablet when the launcher has stopped?
Unfortunatly, your launcher is corrupt. The only answer I can see will be a complete restore to factory defaults. Your apps should reload once you sign back on to the app store, be sure to use your original signon and password combination. I had to do this once and everything seemed to follow up.
Good Luck.
Dean
Mar 06, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Why do my tablet says unfortunately vLauncher has stopped and I can get it off the screen
You must uninstall the launcher, if you can't do this, them you must to factory reset the tablet.
Aug 29, 2014 | Tablets & eReaders
My nook hd says "unfortunately, Home has stopped
You can use alternates to the Home app that defaults on Nooks.
The Home app and the alternatives are all what are called Launchers. You can make your Nook look and feel just like any other tablet you have ever seen. I\'ve personally been using one for years called ADW.Launcher on both my Nooks and just love it. The Nooks default default Home launcher is just a bloody pain to setup.
You can still use both launchers side by side. After running ADW.Launcher for a while you will just ask how you ever got around without it and never want to see Home again.
Jul 07, 2014 | Nook HD+
TABLET / LAUNCHER ERROR ANDROID 4.2.1
My tablet recently did the same thing. I tried everything but I eventually had to do a factory reset. Good Luck
Mar 17, 2014 | ASUS Transformers Pad Infinity TF700TWIFI...
Received message: Unfortunatly launcher has stopped
You could try the free GO Launcher HD for Android at the Google Play store, (just Google "Asus tablet launcher"), but I find that if I restart the tablet when it says "launcher has stopped" or even just switch to another screen it carries on anyway, so it's hardly worthwhile installing another launcher for an occasional annoyance (so far anyway, fingers crossed).
Dec 18, 2013 | ASUS Tablets & eReaders
My daughter's new Childpad is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to reconnect to wireless router but no joy. What can I do?
Look. It happened to me and drove me crazy. I was about to brick my new mobile phone. In my case it was the "Moon call log" icon on the home screen. Believe it or not when I remove the icon the error message no more appears when I restart the mobile phone. Then again when I place it (the icon on home screen) the annoying error message "Unfortunately, Launcher has stopped" will comeback again. In your case it could be any icon or widget.
I solved the problem by uninstalling the application and installing it back from Play Store unlike what I did before by installing it from the .apk file.
Regards,
Oct 28, 2012 | Archos 4GB Child Pad 7" Android 4.0 Tablet...
Hipstreet Flare 9 inch Tablet with 8GB Memory and Case Logo
395 people viewed this question
Top Hipstreet Tablets & eReaders Experts
Lawrence Oravetz
ray gallant
Are you a Hipstreet Tablet and eReader Expert? Answer questions, earn points and help others
