Question about HP PSC 1215 All-In-One InkJet Printer
When am ON the printer just coming display then going to OFF the machine
    Habit-Forming:
    New Friend:
  • 56 Answers
Check/replace your memory
Posted on Dec 27, 2013
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
DELETE ALL PRINTER JOBS
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
C3451
Sir/Mam,
On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. The code will come back but now press the Utility/Counter button, you should see a button that says Maintenance Mode press that, see Trouble Reset press that and the machine will again will go thru warm up procedure, you will see the "." DO Nothing! The machine should go to "Ready to Copy" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Jan 03, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Lexmark T630 printer and every time I go to print it beeps and says change tray 1. How to I get it to not beep while printing?
You will need to change your paper handling.
From the machine, go into the Menu-> then Paper Menu -> Change your paper size and type to your machine settings. Example if tray 1 is letter make sure it's set to letter and plain, then confirm each tray setting for each tray attached to the machine.
Also pull the tray(s) out completely and make sure the guides are set correctly. (The guides move so you can put legal, A4 etc.)
I've come across a lot of machines that the guides are off by a fraction which will prompt your machine to display the message you stated.
Nov 16, 2010 | Lexmark T630 Laser Printer
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Just plugged it in from being stored and it is blinking H 4
On the control consol. Press #,*,c,* the display should pop up with a screen to enter a code. Press 14, then enter 1. If the screen comes up blank, then enter 14 as if making 14 copies. Press start, and the machine should reboot and come to ready.
On your machine I believe the screen will go blank and you just enter 14 then start.
if not and a screen comes up with 00-00 displayed, enter 14 then start, then 1 then start.
Feb 16, 2010 | Sharp AR-M205 Copier
XEROX WORKCENTRE M20 WHEN POWERING UP MACHINE IT WILL NOT COME OUT OF WARM UP MODE. FUSER IS HOT. MACHINE DISPLAY WILL SAY WARMING UP, MACHINE WILL CYCLE, SCANNER WILL MOVE , PRINTING WILL APPEAR ON...
what you want to do is this, turn the machine off. Remove the back cover. Then on the main board you should see a memory stick or 2 depending on the model.
Remove the memory sticks, then power up the machine with them out. Let it come to ready, then re install the memory sticks and power the machine back up to remove any software corruption.
Apr 08, 2009 | Xerox WorkCentre M20 All-In-One Laser...
Xerox workcentre m20i turns off
Sounds like the machine software is corrupted.
Try this first. Turn the machine off, then on back, there is a panel on the back cover with to plastic tabs that will release it. Pop that off and remove both memory sticks.
With the sticks removed, turn the machine on and let it come to ready. Shut the machine off , replace the memories and turn the machine back on, That reloads the machine software cleanly.
If that does not work. Go to Xerox.com, click on support and drivers, enter M10 into the search box, then click on Drivers and Downloads. Once there go to the firmware and download in with the instructions . I think the level is at 3.04 now. follow the instructions to install the firmware.
One of those 2 should resolve your problem.
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Canon Pixma MP530 - Want to setup machine & phone properly
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
No Display
in response to the previous response, does the printer have to be under warranty to receive the free replacement?
Jun 02, 2008 | Xerox Phaser 8550DP Printer
HP PSC 1215 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
