Question about Dell XPS 730X Desktop Computer
Theater lightning batteries?
Where is the batteries compartment for XPS-730x Theater Lighting? I can't find it...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Battery compartment is on the rectangular case attached to the sides of the hard drive units, you need to remove the screws on the cover to remove it then replace the batteries inside if needed.
Posted on Dec 28, 2013
LG home theater has no power after lightning strike
Hi Tarbo, You're going to have to actually get inside it and replace any fuses that has blown..................CHEERS..
May 10, 2016 | home Audio Players & Recorders
Philips DTM3170/12 CD Lightning Micro System
It has an audio input, a 3.5mm cable you can connect to the headphone or speaker jack on your computer. The USB likely won't work with a computer as it usually requires a particular file structure; something simple like you'd find on a flash drive, ipod, or some phones.
Apr 04, 2015 | Philips Audio Players & Recorders
Ho do I open a Denon remote control unit
Make sure there are no hidden screws , top and bottom of remote snap together, usually top snaps over bottom so you have to slide something between halves and push in on bottom or pull out on top to get them to seperate.
Nov 18, 2014 | Denon Dvd Home Theater System Remote...
Bose 321 will not power up after power surge or possible lighting strike on our boat , tried 60 second reset
Do you have power to it or are you just doing the reset procedure with it dead? If you had a lightning strike then you need to check everything starting with the fuses wiring and if it applies the inverter. No brainer check is the battery itself.
Nov 12, 2012 | Bose (321GS) System
2000 chevy monte carlo door latch assy. replacement
all the lights above the dash do not work ?????? DOME light's ??? No light's come on when you open the door or any door ? Wouldn't think all the door ajar switches bad at one time .
Interior Lamps
The interior lamps consists of two groups, lamps that can not be dimmed and lamps that can be dimmed. This first group consists of lamps that may not be dimmed. This Includes those lamps that may be manually turned on by placing the interior lamp switch to the DOME position, or by opening a door or a compartment:
• Auxiliary dome lamp (SEO, RPO 6C7)
• Dome lamp
• instrument panel (I/P) compartment lamp
• Inside rear view mirror lamps
• I/P courtesy lamps
• Reading lamps
• Rear compartment courtesy lamp
• Sunshade vanity mirror lamps
Battery positive voltage is applied at all times to the DIC/RKE fuse and to the switched side of the BATT RUNDOWN PROTECTION relay in the right I/P junction block. The DIC/RKE fuse supplies battery positive voltage to the coil side of the BATT RUNDOWN PROTECTION relay. When the ignition is turned to the ON position, the body control module (BCM) provides a ground to the Inadvertent relay control circuit. This energizes the BATT RUNDOWN PROTECTION relay and applies battery positive voltage to I/P BRP fuse and to the TRK/ROOF/BRP fuse. Battery positive voltage is applied from the I/P BRP fuse to the I/P courtesy lamps, I/P compartment lamp and to the I/P compartment feed circuit to the BCM. Battery positive voltage is also applied from the TRK/ROOF/BRP fuse to the:
If the BCM receives a door lock or unlock input signal, the BCM will activate the BATT RUNDOWN PROTECTION relay, which provides battery positive voltage to all interior courtesy lamps. When any door is opened, the door jam switch contacts close and the BCM receives a door-open input signal. The BCM then applies a ground to the theater dimming ground control circuit illuminating the courtesy and dome lamps.
After all the doors are closed, the courtesy lamps remain illuminated for approximately 40 seconds. The courtesy lamps will also turn on and remain illuminated for approximately 15 seconds after the ignition key is removed, prior to any door being opened.
When the headlamp switch is placed in the DOME position, the BCM receives a ground signal. The BCM then applies a ground to the theater dimming ground control circuit. This illuminates the dome and roof rail lamps.
The courtesy lamps will normally turn off using the theater dimming feature. The BCM provides a pulse width modulated ground to all courtesy/reading, dome, and inside rear view mirror lamps for the theater dimming feature. The BCM will immediately turn off the courtesy lamps if a door lock command is received with all the doors closed, or if the ignition switch is turned to either the ON or RUN position.
The BCM activates the interior lighting output 15 seconds after receiving the class 2 message "Airbags Deployed" from the sensing and diagnostic module (SDM). The interior lamps remain activated for 25 minutes.
The door ajar switch is part of the lock actuator inside the door !
Jul 01, 2017 | 2000 Chevrolet Monte Carlo
My rca RT2870 turns itself on and the remote cannot be used either. I have to get up and walk over and manually turn it offand before I get back over to my bed it comes on again by itself. It did this 5...
The problem could be from the remote control, check if the RCA theater system do function by pressing the button on it , if this responds meaning that your remote control is faulty.
Defective RCA theater remotes can be repaired. A remote control that does not respond well or that does not work at all probably has worn or defective component parts. Before investing in a replacement remote controller, first test the RCA theater unit to determine if it is not working properl4y. If all systems are in order, consider troubleshooting the remote control with some simple household tools and materials.
Things You'll Need:
Mild soap
Cloth towel
Pencil eraser
Fiberglass brush
Cotton balls
Phillips screwdriver
Aluminum foil (silver and copper)
Epoxy
Step 1
Check to see if the remote is not operating properly because of a bad theater. Press the power button on the RCA theater unit to make sure that the unit itself is working. Put in a dvd plate, press play on the RCA theater unit; if the dvd is playing, there are no problems with the unit. Press the stop button from the remote control. If the RCA theater does not respond, then the remote may be bad.
Step 2
Narrow down the problem using an infrared radiation (IR) detector. The IR may have been switched off, causing interference and range problems between the VCR and its remote. Hit the RCA theater menu button on the unit and search for the IR signal sub-menu. Confer with the remote owner's manual to get the specific codes on resetting the IR signal or simply reset the IR detector back to its factory setting.
Step 3
Clean or replace batteries. Old, corroded or dead batteries can be the cause of the remote malfunctioning. If batteries look corroded, clean off chemical deposits with a soft brush and remove debris with a lint-free cloth. Polish the ends of the batteries (the contacts) with a fiberglass brush or pencil eraser. If batteries appear to be dead, replace with new ones, positioning them in the correct order as identified in the battery compartment.
Step 4
Clean out the battery compartment. Sometimes, it may not be the batteries causing the remote to malfunction, as gunk and dirt can accumulate in the battery compartment and cause the buttons to not respond to pressure. Remove stubborn crud inside the battery panel with a pencil eraser.
Step 5
Disassemble the remote control's front panel with a small Phillips screwdriver. Use a minimal amount of water and mild detergent to wipe away grime and sugar deposits that may have formed around the rubber membrane keypad, circuit board and plastic case (use caution to not directly expose circuit board to liquids). Use a cotton ball to wipe down with isopropyl alcohol. Allow remote's contents to dry thoroughly before replacing components.
Step 6
Correct a worn keypad on remote. According to Shaw Direct, "if you can see the rubber through the conductive material after cleaning, the pad is likely worn to the point of being non-functional." Disassemble the front cover of the remote, exposing the keys and its worn rubber keypad. Use epoxy to glue the aluminum or silver foil onto the control's rubber surface--make sure that you have cut out enough holes for the keys to fit over the foil before gluing. Replace front cover. Consider investing in a remote control keypad repair kit for seriously damaged rubber keypads.
Hope this help
Jun 16, 2010 | RCA RT2870 Theater System
XPS 730 LED light issue...
you might want toreplace the theatre lighting card.
good kuck
Sep 16, 2009 | Dell XPS 730X Desktop Computer
Dell xps 730 does not boot
I think it is a problem with your RAM memory. If you have 2 dims extract one and try to boot if not work extract the other one and try.
Jul 18, 2009 | Dell XPS 730X Desktop Computer
Dell XPS 730X PSA test '2000-1002' error
Dell's own policy is 3 major components and then replace it. remind them of there policy and they will replace the hole system.
Apr 28, 2009 | Dell Computers & Internet
Dell XPS 730X Desktop Computer   Logo
Alun Cox
