Question about Canon Laser Class 310 Fax
What is the toner model number for canon L380 fax machine???
  • 37 Answers
Cartriadge T or EP-25 after removing the drum cover
Posted on May 23, 2009
Taking toner out of l380 fax
1. Remove any documents and/or printed pages from the machine.
2. Make sure the machine is plugged in.
3. Remove the cartridge from the bag. Keep the bag in a safe place for future use.
4. Gently rock the cartridge several times to evenly distribute the toner inside.
5. Hold the cartridge on a flat stable surface with one hand, and break the tab and pull out the seal completely with the other hand.
6. Open the printer cover.
NOTE:
If you are replacing the old cartridge with the new one, remove the old cartridge from the machine. Then, discard the old toner cartridge immediately according to the local laws and regulations for disposal of consumables.
7. Hold the cartridge and position the arrow mark on the cartridge towards the inside of the machine.
8. Align the projections (A) on both sides of the cartridge to the guides (B) in the machine and slide thecartridge completely into the machine. (See diagram below)
Oct 16, 2012 | Canon FAX-L380 Plain Paper Laser
How scan from this fax?
1 Load the document in the ADF.
2 Press [COPY].
3 Use the numeric buttons to enter the number of copies. (up to 99)
4 Adjust any necessary settings for your document.
5 Press [Start].
NOTE
To cancel copying, press [Stop/Reset].
Dec 09, 2011 | Canon FAX-L380 Plain Paper Laser
Fax -L380 canon error cod Eooo
Fixing assy failure. Replace fixing assy.
May 18, 2010 | Canon FAX-L380 Plain Paper Laser
Cannot recieve or send faxes. Machine can still copy though. says "change paper size"
Unplug the fax from power for a minute or two.Check the paper size under fax sett., clean rollers,...
Feb 16, 2010 | Canon FAX-L380 Plain Paper Laser
Install cartridge on the display but the cartridge is ok
Hi, check the crg. is there any leftover from toner band? It also can be tht is problem with crg contact on fax, try with wd-40 small amounts if not send the message
Nov 15, 2009 | Canon FAX-L380 Plain Paper Laser
My canon laser jet fax L380 will not receive faxes. The line has been tested and is OK, but just rings out when called. The machine is set to "fax only" so should receive faxes without any problem.
There are only 3 possibilities that I am aware of that can cause your issue. 1) Is the fax only setting you mentioned which is correct and it should answer. 2) The machine has somehow been set in distinctive ring mode. This causes the machine to ignore a normal incoming ring tone and wait for a special tone. If you have your manual you can look up this setting there. 3) The modem has gone bad in your machine. These can rarely go bad on their own or can be damaged by power surges or lightning damage(just in case you have experienced either of those)
Oct 21, 2009 | Canon FAX-L380 Plain Paper Laser Fax
I cant send fax
Its laser related error, probably laser controller pcb faulty, most best solution is to buy new fax, eg Canon L140/160. Its by my opinion OK and durable fax
Dec 18, 2008 | Canon FAX-L380 Plain Paper Laser
Canon fax L380
the cartridge is faulty Replace it
Sep 03, 2008 | Canon FAX-L380 Plain Paper Laser
Canon Laser Class 310 Fax Logo
90 people viewed this question
old marine
old marine
