Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Vaccum has no suction
shared by 4 users
posted by jocelang on Oct 17, 2007
my vaccum sucked up a ribbon while vaccuming. i stopped the vaccum and pulled the ribbon out. when i restarted the vaccum it smelled like it was burning and the brush on the bottom was not spinning. also, there was no suction so it was not cleaning.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Posted by Guest on Dec 16, 2007
i have the same problem, instead of sucking the air, it is actually blowing the air.. can any body help ..plz
Posted by johnnyguitar on Dec 04, 2007
i have same problem i have cleaned vac have no suction in hose or at bottom of vac
Posted by Guest on Dec 02, 2007
My vaccum has suction but it is not picking any bits up from the carpet. i have changed the bag, cleaned out the hose and all seems fine, but my carpets are still dirty. please help.
Best Solution
posted on Oct 20, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Need a new belt -- you might have suction but you need the brush to spin (hard to help without make or model, upright or canister)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on vaccum has no suction:
I don't want to Accept this solution
Solution #2
posted on Feb 07, 2008
Not Rated (0)
Geterdun
Rank:Wiz Wiz
Rating: 84%, 71 votes
hey guys: just hit the little red reset button,but only after you cleaned out the brushes.
Thank You!
Solution #3
posted on Dec 18, 2007
Not Rated (0)
Geterdun
Rank:Wiz Wiz
yes the burning smell is caused by the belt,so change it. also check each side of the brushes. there are bearings on either side. you may be able to pull them off and clean them out. next check the filters. if they are clogged then you will have poor suction,so change them. the other clog might be in the hose. you will have to snake it out. if you can't do it with ease then the hose will have to be taken apart. both ends of the hose can be taken off. if you are going to try this,first start with the end which goes into the canister. the other side of the hose is harder and care has to be taken or it will break off--------------BY GETERDUN
Comment posted on Dec 18, 2007
to guest on dec 17
check the bottom for the canister. you may have a cracked base. if this is true then you have air being sucked in from crack in base. you will have to replace the base. be CAREFUL taking the wheels off. replacing base means taking motor,pc board or relay,cord reel,and wires to the hose off and placing in new base. make sure to mark old model # on to new base.
Thank You!
Solution #4
posted on Nov 19, 2007
Not Rated (0)
1952
Rank:Wiz Wiz
Rating: 86%, 69 votes
the brush belt as broken ,this is the smell of burning
Thank You!
Solution #5
posted on Nov 10, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I had the same problem. First I disconnected the hose that attatches to the top of and bottom back-side. Make sure it is not clogged. Mine was clogged so I used a wire coat hanger and carefully pushed all the junk out. also I turned the vac over on its front, took the metal plate off the bottom, and dug out any extra stuff that I saw. you would be suprised how much hair and junk gets caught. Then I put it back together and replaced the bag. It worked like new for me. Hope this helps.
Thank You!
Solution #6
Not Rated (0)
Guest
Rating: 0%, 0 votes
check Belt - if your vacuum has a hose check it for suction --(make and model - canister or upright?) If belt is broken it does not matter how much suction you have - you need aggitation to clean carpet.
Ralph
ifix@shentel.net
Thank You!
Can you Help with these Vacuums problems?
Kenmore 25614 / 25615 Progressive Bagged...
Did you find a manual yet for your Kenmore Progressive...
When using powerhead I lost motor power so I took the...
I have the same problem thats been mentioned by others. I...
The plastic adjustment connector that clips to the steel...
Recently replaced the brush roller assembly, but even...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
