Question about Xerox Office Equipment & Supplies
089-311 error code for xerox copier Dcc3000 - Xerox Office Equipment & Supplies
  • 2072 Answers
SOURCE: Xerox Copier Machine - Error U4
The fuser is not warming up.
On that machine under the web there is a thermal fuse on a white plastic mount, it has one screw through it.
It is most likely blown. Possibly caused by a jammed paper in the fuser.
That fusable link needs to be replaced.
Posted on Jan 02, 2008
  • 42 Answers
SOURCE: Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Posted on Jun 30, 2008
checkitright
  • 1362 Answers
SOURCE: xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Posted on Aug 11, 2008
  • 2072 Answers
SOURCE: LSU error code
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Posted on Sep 17, 2008
checkitright
  • 1362 Answers
SOURCE: U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Posted on Oct 06, 2008
Error code 010-319 on xerox DP 700 ?
error code 010-319 replaced fuser still the same
Jan 01, 2012 | Xerox DocuColor 12 Color Copier
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
went to xerox site , look for 3535, type in error code, saw what the problem was.
Jul 16, 2008 | Xerox DocuColor 3535 Copier
485 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
