Question about IBM xSeries 226 Server
1962 operatin sytem not found - IBM xSeries 226 Server
What kind of fuse does the clock use on a 1962 ford thunderbird
It takes a 1amp 12v. buss fuse. (the short one). Buss fuses are small glass tubes with metal caps on the ends.
Jul 24, 2014 | Ford Amt 1962 Ford Thunderbird 125 Model...
How does the clutch on a 1962 sunbeam work
All the following from memory of my 1962 Rapier Series IIIa that I sold over thirty years ago so need checking.
It's hydraulically operated (Lockheed if I remember correctly).
The push rod from the slave cylinder operated the clutch release bearing (USA: throw out bearing) via al pivoting lever. The bearing is a graphite block held in a cast iron carrier, not a ball bearing unit as found on modern clutches.
The clutch itself consists of the flywheel and clutch cover, both bolted together and driven by the engine. The clutch cover uses six strong coil springs (not the more modern diaphragm spring) to clamp the driven plate to the flywheel. The driven plate is lined with friction surfaces like brake friction parts and it transfers the drive from the engine to the gearbox via a splined shaft.
When the clutch pedal is depressed, the release bearing presses on part of the sprung clutch cover and via some short levers, unclamps the driven plate. The engine can now turn freely without moving the rest of the drive train.
Alternatively, look up How Clutches Work HowStuffWorks This link has a video but it shows a diaphragm clutch although the principle is the same.
Apr 27, 2014 | 1962 Sunbeam Alpine
Error '1962: No Operating system found. Press F1 to repeat boot sequence'
What is the size of the download OS, which is giving error '1962' while installing?
This is error code for faulty or incomplete OS.
Jan 18, 2014 | Microsoft Windows XP Professional
I jst bought used IBM 8183 Thinkcentre every time
You will need to install Windows. If you have an install disk, insert the disk into the optical drive and restart the computer. Go into BIOS and select "Boot from CD/DVD". Follow the install instructions on screen.
Apr 12, 2011 | IBM Computers & Internet
My PC hav bin using windows starter and i change the operatin sytem to windows seven pro which was not genuine? and now it has been attacted by virus it can not automatically repair its self, and again i...
its easier to reinstall the whole OS than to try and fix it. Get your data off and reinstall the OS..properly this time!. Do it disconnected form the internet. First thing is install Avast Internet Security and scan the PC thoroughly.
Jan 07, 2011 | Microsoft Windows Vista Ultimate Edition
My computer is telling me that the operatin system cannot be found what would be the problem
Your operating system has been deleted from the c: windows folder so to fix the problem format your pc
Thanks
May 20, 2010 | HP Pavilion 7840 PC Desktop
Where is the temperature sending unit located on a 1962 Cadillac 390 v8?
Normally these can be found on the intake manifold, near to the thermostat. They screw in to the water jacket. Also look on the heads..
Feb 18, 2010 | Cadillac DeVille Cars & Trucks
I need to restart my laptop to factory settings
if you want it to be factory settings, you would need the exact same Operatin Sytem installation disk which they probably didnt give you. The reason i say the same is because your serial numbers wont match as your original OS. Anyways if you only doing it to sell the laptop or two have a fresh Operating system, i would recomend you !1) Get a copy os Windows XP
2) Backup all your important files
3) Format your laptop and reinstall XP
4) Restore your files
5) Download (If you dont have it already) your drivers for your laptop. This can be found on Toshibas website.
6) Install all drivers and thats it. You have a Factory Set Laptop
Apr 30, 2009 | Computers & Internet
1962 operating system not found
Check the computer BIOS to see if the HDD is being detected correctly
Check the computer's BIOS for the Boot sequence (the order in which The BIOS seek a device with a Bootable operation System). Verify that the HDD is on the list.
Boot you comuter with a Floppy containing MSDOS Boot Strap (just go to a computer with a win9x system and do
Code: format a:/u/s and see if you can access you HDD and see the Files on the first partition:
Code:
a:\>c:
c:\>dir This will tell you there is Valid Partition on the HDD.
I will be lurking here for your response,
Gabriel __________________
Real stupidity beats Artifical Intelligence
Avatar courtesy of A D E P T user_offline.gif quote.gif Gabriel View Public Profile Visit Gabriel's homepage! Find More Posts by Gabriel post_old.gif October 18th, 2004, 06:17 PM #3 Beonarri vbmenu_register("postmenu_540105", true); Registered User
Join Date: Oct 2004 Location: Detroit Posts: 18 My computer is back up and running! smile.gif smile.gif smile.gif
I looked around the net for some information on the error and it turns out a simple Boot Disk fix is all it needed.
Thanks for you help anyways, Gab!!
Here's the link for the info:
http://www.cybertechhelp.com/forums/...highlight=1962
It's the forth poster.
Mar 09, 2009 | IBM xSeries 226 Server
IBM xSeries 226 Server Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
