Benson aircon E4 error code
Our aircon still runs but not so cold? E4 is the error showing on the display
SOURCE: centrex airconditioner
I bought a house with one already installed. Found that it isn't switching from 'hot' to 'cold' After time the unit will beep and flash LED's on the unit itself and then switch off. Rather handy on 40 degree days. Good luck sourcing parts for the unit as the company have gone bust. I do know an honest working fellow that installs units - he suggests that Kelvernator are a no go, Mitsubishi, Panasonic are the ones to look at. Pay the extra cash for a brand name, they're less likely to go bust for a start, and if there is a problem, parts are readily available.
Posted on Jan 09, 2008
SOURCE: E4 Error code on APE07AHM1
I emptied the water tray. Viola!
Posted on Jul 17, 2008
SOURCE: Highlander KYD-25/c Error E4 displayed
You want to look up Guangdong Chigo who are the manufacturers of this unit. They have a list of error codes/service manuals etc on their site.... From the PDF:
"1、Check whether the operation current and power of the unit is abnormal. 2、Check whether the speed and wind quantity of the fan is normal, otherwise replace the outdoor fan or capacitance 3、 Check whether the surface of the condenser is too dirty, and it should be cleaned when it is too dirty. 4、Check whether the unit is short of the refrigerant, add the refrigerant after leakage detection and repair welding. 5、 Check whether the sensor and electric control board is normal, otherwise replace the board."
Posted on Jun 24, 2010
  • 57 Answers
SOURCE: I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Posted on Jul 16, 2010
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
It seems the compressor is not switching on the air con blows cold air but not as cold as it should be. It shows an E4 on the display.
Is this a house, a car, a portable AC? We can't help you look up error codes without a model number. Details pls.
Sep 25, 2014 | Heating & Cooling
What is E4 error code o. Yonan airconditioner?
My yo nan midwall split aircon is displaying an E8 error code. What is the fault?
Aug 12, 2013 | Heating & Cooling
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
My carrier aircon model WCARG019EE is not cold & theres E4 code what does it mean?
According to the Owners Manual, E4 is a fault code that requires service by an authorized Carrier Serviceman. No other explanation for it was given.
Sorry I could be of more help.
Apr 29, 2011 | Carrier XCB123D Air Conditioner
Airtech aircon gives an E4 code and then goes off = what causes this and how do I remedy it
Two days ago we had an Air tech Airconditioner installed and it is showing an error FE what is this pls?
Sep 04, 2010 | Heating & Cooling
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
Jan 22, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
